08-04-2006, 04:37 | #1 (permalink) |
Temporary banned !! Join Date: Jul 2005 Location: Palestine Age: 37
Member: 165433 Status: Offline Thanks Meter: 72 | problem with new ap75 Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Skip: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Err: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Err: error flash command try to recover erase error#43 |
08-07-2006, 10:54 | #5 (permalink) |
Member: 165433 Status: Offline Thanks Meter: 72 | with unlock reading backup erasing writing failed phone unlocked no problem with flash after erasing writing failed phone no power on i test in more pc and cable com interface the problem in b-module |
08-08-2006, 21:52 | #8 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 45
Member: 174505 Status: Offline Thanks Meter: 1 | I unlocked yesterday one pcs AP75 from movistar .... with infinity and test point work 100% .... look at the log COM3 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: Backup_eeprom-00_2006-8-7_15-42-40.4BF.bin Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Writing Done Finished Remove/Install battery now ! Time used: 51 sec |
08-14-2006, 13:12 | #9 (permalink) |
Junior Member Join Date: Aug 2005 Age: 47
Member: 175095 Status: Offline Thanks Meter: 0 | yesterday ap75 flashing error COM4 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Err: error flash command try to recover erase error#43 |
09-04-2006, 15:36 | #10 (permalink) |
No Life Poster Join Date: Jan 2001 Location: Bucharest, Romania Age: 48
Member: 3180 Status: Offline Thanks Meter: 12 | ap75 movistar dead after unlock..then i try to flash but.. COM3 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Err: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0089:885500010001 Err: error flash command try to recover erase error#43 Writing Fail Finished |
09-04-2006, 18:48 | #11 (permalink) | |
Download latest BModule from support area and try to repeat unlock/flash process. | |
problem with new smart clip with boot-loader | sameenshah123 | Smart-Clip | 3 | 03-25-2010 11:42 |
...::: New Problem With New Sharp Gx17 Blue :::... | MATRIX.REAL | Sharp | 6 | 07-09-2008 16:26 |
New Problem with New K750I | clinic*mobile | Cruiser Suite | 9 | 02-09-2007 19:33 |
New Problem With New Motorolla V80 | ahfid | Motorola P2k | 1 | 06-29-2005 19:53 |
BIG PROBLEMS WITH NEW NOKIA UNLOCKER | Mediamag | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-20-2000 20:32 |
