GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   problem with pin finder. (https://forum.gsmhosting.com/vbb/f296/problem-pin-finder-615913/)
digitized 10-23-2008 08:22
i have problem with my pin finder it always show me this type of error....
Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.14
Smart-Card S/N: 37DA
Smart-Card firmware version: 0111
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
searching adapter at COM4...
adapter found, version: 2000
Serial No: *******************
done
Initializing...
done
Cable: 2x5 (L10B)
cable type: 2x5 (L10B)
platform: MT: MT62xx (autodetect)
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
Press and HOLD phone Power button now !
detecting pins...
too many retries
too many retries
too many retries
connection w/adapter lost during set Tx as pin 6
failed to detect pins
time required: 7 sec
too many retries
too many retries
too many retries
Power On !
then if i again try to find it it show me this type of error and does not detect adapter..then i have to restart whole software....plz guide where is problem.....:confused: it is box problem or some settings ha done ....plz guide me ...
too many retries
can't find adapter
too many retries
too many retries
Power On !
Sethxp 10-23-2008 09:25
Is your red led on pinfinder active during pinout detection ? It looks like phone you try dont have rx/tx in connector but by testpoints on pcb.
digitized 10-23-2008 10:21
yes red led active during pinout detection...
but this handset which i put log above hare dtect pinout on oyther box ...
i may confuse where is problem.....pls help infinity team .....
digitized 10-23-2008 14:17
is there is no body know what is problem.....:confused:
digitized 10-23-2008 14:28
InfinitySupport 10-23-2008 15:25
Hello,
Please, check PinFinder manual page 20.
At first you need to check voltage at unibox pin-1, more information with pictures) can be found in manual.
p.s.
in case of repeated posts each 10 minutes we will close thread just after we will see repeated posts.
digitized 10-23-2008 16:01
Originally Posted by InfinitySupport (Post 3772995)
Hello,
p.s.
i will not repeat post never it is happen due to my net problem....sry fr that....:(
InfinitySupport 10-23-2008 16:45
Hello,
Any luck with voltage measurement ?
digitized 10-24-2008 05:49
Originally Posted by InfinitySupport (Post 3773220)
Hello,
sir i will check and post result...
thanks for ur reply ....:)
digitized 10-25-2008 05:07
Hello,
yes i have check the volt on unibox pin no 1.......it is less than 5 v as say on ur 20 no.page in ur manule .....the volt is 4.83v i am using slim unibox ....did i have apply jumper to diode in unibox .....:confused:
InfinitySupport 10-25-2008 07:34
Hello,
Yes, it\'s better to make so.
Qaisar Mahmood 10-30-2008 09:32
I use to Pinfinder. But Same Problem. Software version: 1.14
too many retries
can't find adapter
too many retries
too many retries
Power On ! I Perchaze the New Pinfinder. Plz help me Infinity team.
InfinitySupport 10-30-2008 13:01
Hello,
At first you need to check voltage at unibox pin-1, more information with pictures can be found in manual.
shinod 10-31-2008 04:57
fisrt pin voltage is 5 volt but same problem what can i do please help me...........
Qaisar Mahmood 10-31-2008 06:37
Sir, I check fisrt pin voltage is 5 volt but same problem what can i do please help me...........
Page generated in 0.19470 seconds with 7 queries
