Old 10-23-2008, 08:22   #1 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
problem with pin finder.
i have problem with my pin finder it always show me this type of error....
Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.14
Smart-Card S/N: 37DA
Smart-Card firmware version: 0111
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
searching adapter at COM4...
adapter found, version: 2000
Serial No: *******************
done
Initializing...
done
Cable: 2x5 (L10B)
cable type: 2x5 (L10B)
platform: MT: MT62xx (autodetect)
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
Press and HOLD phone Power button now !
detecting pins...
too many retries
too many retries
too many retries
connection w/adapter lost during set Tx as pin 6
failed to detect pins
time required: 7 sec
too many retries
too many retries
too many retries
Power On !
then if i again try to find it it show me this type of error and does not detect adapter..then i have to restart whole software....plz guide where is problem..... it is box problem or some settings ha done ....plz guide me ...
too many retries
can't find adapter
too many retries
too many retries
Power On !
Old 10-23-2008, 09:25   #2 (permalink)
Sethxp's Avatar
Member: 9291
Thanks Meter: 84
Is your red led on pinfinder active during pinout detection ? It looks like phone you try dont have rx/tx in connector but by testpoints on pcb.
Old 10-23-2008, 10:21   #3 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
yes red led active during pinout detection...
but this handset which i put log above hare dtect pinout on oyther box ...
i may confuse where is problem.....pls help infinity team .....
Old 10-23-2008, 14:17   #4 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
is there is no body know what is problem.....
Old 10-23-2008, 14:28   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
Old 10-23-2008, 15:25   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,482
Hello,
Please, check PinFinder manual page 20.
At first you need to check voltage at unibox pin-1, more information with pictures) can be found in manual.
p.s.
in case of repeated posts each 10 minutes we will close thread just after we will see repeated posts.
Old 10-23-2008, 16:01   #7 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
Originally Posted by InfinitySupport View Post
Hello,
p.s.
i will not repeat post never it is happen due to my net problem....sry fr that....
Old 10-23-2008, 16:45   #8 (permalink)
Member: 130995
Hello,
Any luck with voltage measurement ?
Old 10-24-2008, 05:49   #9 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
Hello,
sir i will check and post result...
thanks for ur reply ....
Old 10-25-2008, 05:07   #10 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,694
Hello,
yes i have check the volt on unibox pin no 1.......it is less than 5 v as say on ur 20 no.page in ur manule .....the volt is 4.83v i am using slim unibox ....did i have apply jumper to diode in unibox .....
Old 10-25-2008, 07:34   #11 (permalink)
Member: 130995
Hello,
Yes, it\'s better to make so.
Old 10-30-2008, 09:32   #12 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,904
I use to Pinfinder. But Same Problem. Software version: 1.14
too many retries
can't find adapter
too many retries
too many retries
Power On ! I Perchaze the New Pinfinder. Plz help me Infinity team.
Old 10-30-2008, 13:01   #13 (permalink)
Member: 130995
Hello,
At first you need to check voltage at unibox pin-1, more information with pictures can be found in manual.
Old 10-31-2008, 04:57   #14 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
fisrt pin voltage is 5 volt but same problem what can i do please help me...........
Old 10-31-2008, 06:37   #15 (permalink)
Member: 226457
Sonork: 100.1604561
Sir, I check fisrt pin voltage is 5 volt but same problem what can i do please help me...........
Cect V329 - cannot detect pin with Pin-finder loukandr Infinity-Box 17 03-18-2009 19:58
Problem with Pin Finder Adapter BouRRi_GSM Infinity-Box 14 07-18-2008 23:24
Help With Nokla 6300 With Pin Finder palash_c6 Infinity-Box 2 05-06-2008 17:23
proplem with pin finder amrsayed30 Infinity-Box 15 04-13-2008 14:06
cect q380 can't find pin outs with pin finder kiran Infinity-Box 4 04-09-2008 09:12
Page generated in 0.44072 seconds with 8 queries
