11-12-2008, 17:25 | #31 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I think 4.97 is Ok. Check PinFinder manual page-19, it may be small problem with L8A cable, problem can be solved very easily, picture is exist in manual page-19. |
11-12-2008, 19:42 | #32 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | I have still problem with L5A cable, and almost the same messages appear: software version: 1.15 cable type: 1x5 (L5A) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM1... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries warning: 2nd answer absent too many retries failed to detect pins time required: 38 sec too many retries too many retries Power On ! Set parameter to value 20 (or more) and repeat operation "Finder activation tries" |
11-13-2008, 11:00 | #34 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I just opened now the L5A cable and I see that here is no Grey wire like in Picture from page 19 of the manual to cut. And inside there are just 5 wires,respectively Orange, Yellow, Red, Brown, and Black wires. And the same with the L8A cable: There is no Grey wire connected, but not just Grey but no wire is connected to that Pin of DR26 cable BR |
11-13-2008, 11:27 | #35 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Vodafone 125 is Powered on through Pinfinder correctly and I select Pinout from List then I press Set, and then: too many retries too many retries too many retries too many retries So i never succeed in Setting any configuration |
11-13-2008, 16:32 | #36 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I think you have a reason to open your Unibox and short diode according to PinFinder manual page 19. Please, do it and then repeat any test with PinFinder. |
11-13-2008, 18:32 | #38 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I opened earlier today Infinity Unibox and short the diode according to manual on Page 20. Also today I checked the wires of DR26 cables and they were not present. So now is the last option like @Qaisar Mahmood says. Can you confirm officially the work of @Qaisar Mahmood, or should I return the Pinfinder to the reseller? I think that Pinfinder is working good because when I detect it with the software it is detected well, but after I try to "SET" pins there is "too many retries" message. BR |
11-13-2008, 19:01 | #40 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If somebody had the problem and problem gone after replacing some IC this means that IC was damaged. I am not sure that it will works in your situation, but in fact PinFinder has not so many components and it may be that this solution will be good for you. Anyway, I suggest you to contact to your reseller first and talk with him, it may be that you can replace PinFider by warranty, but if you can try to replace 4051 you can do it too (but I think it will be better to contact to your reseller first). |
11-14-2008, 13:38 | #42 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | I don't understand why should I make so many interventions on new device? Why factory doesn't make them OK without end use changing anything? BR |
11-17-2008, 18:48 | #45 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it can not be true. Please, let's start from begin, because it can not be true that two PinFinders can not work. It looks like something wrong with wires, box or PC. So, please, open PinFinder manual and let's make all steps one by one with your detailed comments what you have tried to do and what is results. Please, let me know about result of all steps from PinFinder manual so we can check what is wrong. |
Cect V329 - cannot detect pin with Pin-finder | loukandr | Infinity-Box | 17 | 03-18-2009 19:58 |
Problem with Pin Finder Adapter | BouRRi_GSM | Infinity-Box | 14 | 07-18-2008 23:24 |
Help With Nokla 6300 With Pin Finder | palash_c6 | Infinity-Box | 2 | 05-06-2008 17:23 |
proplem with pin finder | amrsayed30 | Infinity-Box | 15 | 04-13-2008 14:06 |
cect q380 can't find pin outs with pin finder | kiran | Infinity-Box | 4 | 04-09-2008 09:12 |
