03-13-2008, 14:49 | #1 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Problem with Pin Finder Adapter i have problem with my Pin Finder Adapter still can't power on the phone, when power is active on Pin-Finder Software and Red led is active, i mesure voltage in the crocodile, it balance between 2.2v and 3.87v, i try different PC's. when i change in other USB 2.0 port, i got about 4.11V, but phone still can't power on, or sometime it just start power on then shut-down. i try more then 5 chineses working phone, N77, N95, DuBao ... it's appear like current problem not voltage problem any idea?? thx br |
03-13-2008, 15:33 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Please, check what is voltage on your PC USB port and what is voltage on pin-1 at Unibox RJ45. It may be that something wrong with Unibox, so let's check it first. |
03-13-2008, 15:43 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, I think that problem is with voltage at pin-1. If box is not sealed try to open it and replace (or just short) protection diode that goes from USB +5V to pin-1. It looks like big voltage loss took place on it. Also, if you have any other unibox you can try to use it instead of slim. |
03-14-2008, 19:48 | #6 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | problem solved after changing the last passif diode (the big one) under RJ45 connector it's was unormal, input = 5.01, output = 4.61 and sometime down now the voltage on pin1 of RJ45 connector, is same like on USB, 5.01V and the Pin Finder work normally @zinoubi nabil still my new infinity slim under warranty or not?!!? thx infinity team |
03-15-2008, 02:18 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Thanks a lot for report ! PinFinder manual updated, new solution and pictures added: http://www.infinity-box.biz/download..._PinFinder.pdf |
03-16-2008, 17:56 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @alswedi Please, download latest user manual with detailed explanation at page 19 and 20: http://www.infinity-box.biz/download..._PinFinder.pdf |
03-27-2008, 05:50 | #12 (permalink) |
Freak Poster Join Date: Jan 2003
Member: 20312 Status: Offline Thanks Meter: 24 | @infinitysupport now 5 volt out of infinity adaptor after remove daiod and short .but it cant power on all chienes mobiles , some models cant power-on , maybe need more Milliamp to power on mobile ? any help ? |
03-27-2008, 16:52 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, For pinout detection and flash process it's enough if phone can start to power-on (but it's not required to power-on phone completely and find network). |
03-27-2008, 17:00 | #14 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | same for me, some phone can't power on properly, but all job can be done (find pinout, format, flash, repair...) problem still in some needed mA, maybe an external power supply is needed for Pin-Finder V2, or check the regulator inside Pin-Finder adapter, maybe must be replaced by another br |
Infinity Box Pin-finder adapter test report | ezzis | Infinity-Box | 790 | 07-04-2015 22:03 |
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
problem with pin finder. | digitized | Infinity-Box | 47 | 02-14-2009 12:55 |
Infinity Box - Auto Pin Finder Adapter!!! | Hams | Main Sales Section | 0 | 02-09-2008 18:13 |
