Old 08-08-2008, 20:40   #1 (permalink)
Member: 715951
Red face Problem with Pinfinder and new firmware of box
Well, I tried the new chinese miracle with MT6230 supported, because I got a phone with MT6230 waiting to extract the flash. So I needed to upgrade the firmware of box to use this new release of CM... and I did it.
The problem is that pinfinder can't find pinout now!! what the..?
A few days ago pinfinder found pinout of this phone without problem, but now, with updated firmware of box, there is no way to find it...
Where is the problem?
Old 08-08-2008, 23:36   #2 (permalink)
Member: 148515
Thanks Meter: 14,895
hello!
maybe some settings set to default value?
for example: activation tries below 10 do not detect iFOE P168i
7 is default
Old 08-09-2008, 07:41   #3 (permalink)
Member: 715951
I found this pinout with past firmware with default options. Now, the phone can't be powered on, so there is no way to find pinout
How a simple firmware upgrade of box could affect the power of pinfinder?
Old 08-09-2008, 22:42   #4 (permalink)
Member: 148515
hello!
can not for sure.
Does power LED is working?
Old 08-09-2008, 23:21   #5 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,022
chek phone choket is sort
Old 08-11-2008, 07:28   #6 (permalink)
Member: 715951
Well, don't know which was the problem... I downloaded pinfinder 1.11, connect pinfinder again, and now it works.....
But here is the real problem: (tried to read the flash)(the phone is a working model, all perfect, just wanted to translate it)
COM3 [VCP0] selected
Device: Autodetect 6228, 6230 NAND
Checking data, wait...
Action: read NAND flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6230:8A02:8A02]...
CPU: MT6230
high speed boot enabled
chip: 0031:200E:0001
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.020C
loader: 3.748.0
NAND id: ECF10095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
NOR: 0000:000000000000 [00000000]
NAND: 00EC:00F100000095 [08400000]
NOR chip is not installed
Initialize Done
Set baud...
921600
Set baud Done
Identification...
reading structure area...
detecting structure...
warning: incorrect bootloader header: 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A
nfi area detection finished: failed
error: can't detect nand chip parameters, default values assigned
reading...
checking backup data integrity...
warning: probably errors exist during flash read operation
file saved: D:\Archivos de programa\InfinityBox\ChineseMiracle\FLASH Original\CIPHONE_nand_probably_damaged_full_200808 10-205215.B4M.bin
Finished, time used: 4050 sec
Remove/Install battery now !
I uploaded the flash here:
http://rapidshare.com/files/13644832...5.B4M.bin.html
What could the problem be? MT6230 not fully supported yet?
Thanks in advance
Old 08-11-2008, 18:58   #7 (permalink)
Member: 148515
hello!
we will check file and reply
thank you for cooperation!
problem with km900 and new 20 version software simlock Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 01-27-2010 14:45
Tell me about all new firmwares of nokia and also forum containg these firmware updat nofear99 Nokia Base Band 5 ( BB-5 ) 0 11-26-2009 20:59
New model of n95 and new firmware mentari Infinity-Box 9 01-23-2009 20:44
Problem with WINIMEI and D600 "out of memory"? botox SWIFT Platform 2 07-21-2006 21:52
Problem with XP and new Twistersuite ver. 1.16! RTVM Twisterflasher 2 04-05-2004 21:29
Page generated in 0.29681 seconds with 8 queries
