02-27-2017, 16:13 | #1 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1185384 Status: Offline Thanks Meter: 17 | Problem reading MTK nand flash Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0xF3F92EF657613A3E7CF9850EC7E41A6A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_rct6773w22b.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img #85824 : Data CRC Error : FFFF , 4598 Error while reading block! Something went wrong Done! Elapsed: 00:52:02 Reconnect Power/Cable! |
02-27-2017, 17:57 | #2 (permalink) |
Member: 1185384 Status: Offline Thanks Meter: 17 | Another error Card found : S/N : xxxxx , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0xF3F92EF657613A3E7CF9850EC7E41A6A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_rct6773w22b.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img |
03-01-2017, 16:33 | #5 (permalink) | |
Member: 1185384 Status: Offline Thanks Meter: 17 | Quote:
I bought this dongle for making MTK NAND firmwares backup but know I think is useless for me. | |
03-02-2017, 02:54 | #6 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, Nand writing is not supported by CM2. This error generally comes, when there is a problem with cable or connection, or the system partition has been damaged. Try to take backup of any other nand mobile.... Also don't forget to check 'nand extra'option while taking backup of nand mobile.... |
The Following User Says Thank You to chandanps18 For This Useful Post: |
03-02-2017, 14:32 | #8 (permalink) | |
Same errors and problems.. | |
