05-05-2009, 12:30 | #1 (permalink) | ||
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Problem with Rebuilding IMEI in KG110 I receive this set with 00000 Imei. i DOWNLOAD THE The flash file from support & flash the set as direction. KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M This file i download from support & flash the set. Here is the flashing Log. Quote:
Need u r help Infinity team. | ||
05-05-2009, 12:47 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | if u have 00000 in imei then you can repair it by full flash file.if some other figures than you can not repair imei with infinity box |
05-05-2009, 15:30 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | If u followed these steps it must be repaired.. go to"Flash" page:"Firmware (code)": checked : "File system" : un-checked "Alchemy data": un-checked "Eeprom": un-checked Load full flash file via "Load Firmware (code)"button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked this file must be used for flashing..KG110P40-20-V10b_602-03_MAY-31-2007_full_code_alchemy[1].B1M BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
Rebuild IMEI in M620 after flash it became 00000 in easy steps!!!!!!! | graex | UST Pro II | 0 | 06-14-2009 16:55 |
Need help with Rebuild IMEI in 2626 | VICKY4U | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 06-22-2008 08:43 |
rebuild imei LG KG110 | moie70 | Multi-Box | 0 | 11-07-2007 21:03 |
How to rebuild IMEI in NOKIA DCT4 ? | GSM SNIPER | UFS2 + UFS3-Tornadoflasher | 4 | 11-05-2004 21:26 |
