Old 03-28-2009, 13:49   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Problem Removing NP LOCK from ZTE X760
@Infinity-Team
i've just downloaded your update for ZTE X760 pinout found successfully using another box and i used 2 methods to unlock 1 said all locks are off and even 2nd method can not unlock the NP CODE
here is the log.
COM5 [VCP0] selected
module  v2.69
Device: ZTE-X760
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
enhanced security fix enabled
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:EF03:0001
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22312200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.43A79BC1.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_B07A104.BIN_72797161].rpl
New firmware detected (v.2.69, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 43A79BC1
identification#1 protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_B07A104.BIN
ver. sw 2: X760_Z10UK_GD_B07A104, 9E8E868D
ffs offset/size: 00D00000/00300000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_B07A104.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_B07A104.BIN]_20090328-154246.B0E.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation ...
detecting additional parameters...
error: additional parameters detection failed
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_log_43A79BC1_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10UK_GD_B07A104.BIN_72797161_20090328-154414.B0X.bin
Finished, time used: 257 sec
Remove/Install battery now !
==== log: [28/03/2009 3:37:58 PM] ====
module  v2.69
Action: read codes
unlock method: read codes
Model: ZTE-X760
19200 autodetect
CPU: MT6225
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: X760_Z10UK_GD_B07A104
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35235302059654
connection Ok
157 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 0000
Finished, time used: 12 sec
i'm reading full flash file for you as soon as i read it i'll try to upload on rapidshare and will post the link in this thread. but customer is in hurry so can u do anything for me on this issue???
Take Care
ENJOY
Old 03-28-2009, 14:24   #2 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
@Inifinty-Team
thanks i've done unlocking by using Smart Fast method. (Now any Team Member can Change the TOPIC HEADING).
here is the log.
module  v2.69
Action: unlock
unlock method: smart fast
Model: ZTE-X760
19200 autodetect
CPU: MT6225
status: FF
Date: 2006.06.14
Version: 1.0
44 byte(s) read
connection Ok
157 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 15 sec
Take Care
ENJOY
The Following User Says Thank You to imran_qasim For This Useful Post:
Old 03-29-2009, 14:33   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@imran_qasim
Please, read full flash from your phone and send full flash backup to [email protected]
Thank you !
Old 10-13-2009, 11:27   #4 (permalink)
Member: 804308
Sonork: 0000000
COM4 [VCP0] selected
module v2.79
Action: unlock
Model: ZTE-X760
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4203:000D
status: FF
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 77 sec
pls help i am getting such LOG
Old 10-13-2009, 13:30   #5 (permalink)
Member: 130995
module v2.79
Action: unlock
Model: ZTE-X760
19200 autodetect
CPU: MT6225
status: FF
Hello,
You need to press and HOLD phone "power" button during more long time.
Old 04-13-2010, 11:51   #6 (permalink)
Crazy Poster
Member: 463576
which cable am to use with zte x760
Old 04-13-2010, 12:13   #7 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum
Old 04-21-2010, 17:18   #8 (permalink)
Member: 181398
plz infinity firmware bird s301 BD07_S_S301_PCB01_GPRS_MT6223P_S00.V1_00_01_M09110 3CN0-V22F5.BIN
Old 04-22-2010, 21:03   #9 (permalink)
Member: 1043909
Hello,
Could you, please, you read full flash from good working S301 and send full flash image to [email protected] (or upload to rapidshare.com)
How to remove Sim Lock from D820? haveri NSPRO 3 10-13-2006 15:35
how do i remove band lock from z140v cynagon QUALCOMM Models (3G) 1 01-24-2006 16:40
Can't remove keypad lock from VK207? kasner Various 3 04-13-2005 06:49
How I can remove user lock from 1018 00w44? mastergsm Old Ericsson Phones & Sony Phones 8 09-15-2001 17:13
Removing SP Lock from GF 768 cahrisma Old Ericsson Phones & Sony Phones 3 05-26-1999 06:20
Page generated in 0.23136 seconds with 9 queries
