Old 08-30-2018, 21:41   #1 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 188
::.Problem running some programs on my computer.::
Hi, I'm having a few months with this problem
I even changed the windows
I formatted the hard disk
I scanned the computer with a virus
But the problem persists
When i change windows
Just 5 minutes is good
My problem is this error
the application error x0c000005
This error affects these programs-->> sp flashtool-- itunes-- moborobo --qoualcom driver--adb --infinity dongle
For example, when I get out of the zip, it's sp flashtool
There is no problem for 3 to 4 minutes
But then it makes a mistake again
That I must erase
And again from the zip
And use it
I have not been able to erase this error for 6 months
And maybe I change windows more than 70 times
And do all the solutions available on the Internet
I did not give it
I heard this problem from the computer memory(RAM) that my friends said
is it correct?
Old 08-30-2018, 23:31   #2 (permalink)
Member: 2521913
Thanks Meter: 216
I solve my own with Windows 10 from 7
Old 08-31-2018, 06:04   #3 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 188
windowse 7 64 bit
Old 08-31-2018, 10:13   #4 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 188
windowse 7 64 bit
The Following User Says Thank You to afghanistanmob For This Useful Post:
Old 08-31-2018, 10:33   #5 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
More specifically, these errors can be caused by:
Corruption of files in the system.
Problems with hardware.
Incompatible or outdated driver.
Malware infection or virus that corrupted any file.
Third-party software that has mistakenly or maliciously deleted files related to the system.
In relation to your question, to be more assertive for kindness report:
What is the manufacturer and model of your device?
Did you recently add or change some hardware?
Sometimes is your windows its a bad "copy" advice "buy" or "download" another windows from trusted sources.
Old 08-31-2018, 17:14   #6 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,024
@afghanistanmob
Hello,
This error could be due to several reasons-
-Virus, Malware etc
-Antivirus conflict
-Registry problem
-Bad Driver
-Windows
-Ram
-And lastly HDD
So you need to check thoroughly step by step what is causing problem.
Br.
Infinity Box Team.
Old 08-31-2018, 17:25   #7 (permalink)
Member: 2843284
I think it's mostly due to the bad driver) Try to re-install and or update if possible. Sometimes it helps)
Old 08-31-2018, 17:57   #8 (permalink)
Member: 2521913
Thanks Meter: 216
Originally Posted by afghanistanmob View Post
windowse 7 64 bit
I'm using Windows 7 32 bit when I face this problem I update to 10 32 bit that is all
Old 08-31-2018, 19:56   #9 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 188
Thank you all
But I did all this
But the problem is still there
I just did not test the RAM and hard drive
Can it be recognized that it is corrupted or healthy (RAM & Hard drive) With a special program (Tools)
Old 09-02-2018, 14:55   #10 (permalink)
Member: 148515
Thanks Meter: 15,716
as a first step you can test RAM with builtin windows RAM test tool.
to test HDD you can use windows builtin tools also, run test with bad blocks check.
also very useful tool to monitor your HDD health at regular base is CrystalDiskInfo - https://crystalmark.info/en/
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Page generated in 0.32045 seconds with 7 queries
