01-24-2017, 13:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: india
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | problem with SnapDragon 410 [MSM8916] Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0F683FF0 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 34FD2F832B14F7171812FE428FB28260 ID_BLOCK_L : 8144E3D3C25AB1C39145120B88ACF3E9 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! panasonic eluga L2 FRP and 2 asus z010D frp Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1752272A ID_BLOCK_I : 007050E1 ID_BLOCK_L : BF4923DB7AE0ED18C7BC54B986DD5575 ID_BLOCK_L : 0944CA6556F961E2E7D6BB7072BDAB90 Use CM2 Internal Loader Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! |
01-24-2017, 13:47 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: Gujarat,India
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | 4 Asus Z010D Quote:
4 Asus Z010D use this Trick to remove FRP ! https://www.youtube.com/watch?v=FpJ80ra2J_Y | |
07-11-2017, 20:00 | #4 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Bangladesh
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | Full wipe(user/cser/frp) not Card found : 75Exxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Emergency driver NOT found, make sure it installed! Download and install from support area following file : >> InfinityBox_Update_CM2QLM_Drivers_v1.xx.rar Install it, go to /CM2QLM/Drivers/ and install ALL packages inside >> If device detected by PC, but not detected by SW : > 1. Open device manager, find in PORTS section "9008" device > 2. Change (update) driver to Emergency (or) QHSUSB_BULK Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 11A050AF ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00390057 ID_BLOCK_L : 83196E8A041C307AFF3D464A6D383AB2 ID_BLOCK_L : 8820F00A8EC336F94153648D4E5B8CE4 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
07-23-2017, 19:57 | #8 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | this error comes when the loader of that CPU is some secure type , which CM2 does not support , i also have an ELUGA A set with same error for which infinity team says these type of secure loaders are not supported by cm2 yet . so no solution at this time .. |
