07-14-2015, 08:35 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Problem with spd 7715 micromax q324 ALSO TRY TO CHANGE BOTH BOOT Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 49 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 49 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 49 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
07-14-2015, 08:40 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Q324 is SC7731 based phone. Code: Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/SC7731 loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q324 Model Brand : Micromax Model Device: Q324 AndrVersion : 4.4.3 BaseBand CPU: SP7731GEA CompileDate : 1428140737 Project Ver : MMX_Q324_RUS_SW_1.0.7_HW_4.0.0_20150323 Model Ext : Micromax Q324 Elapsed: 00:00:11 Reconnect Power/Cable! |
07-14-2015, 08:49 | #3 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Thanks you but now phone is dead when try to flash with infinity box its says bad file Code: Chinese Miracle II [SPD module] v 1.02 Load failed! Bad file! Nothing to do , select files! THIS FILE FAULT OR WHAT DONT MIND WILL YOU PROVIDE ME THIS FILE |
07-14-2015, 08:52 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | CM2 can't kill it by any way. I sure in that fully. I not have it yet. All files over inet is fake. Already checked. Can make from my own , but not yet. 3-5 days or so. Plan add read FW as well, but later. |
07-15-2015, 06:12 | #6 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | @jaydi now i recover handset with factory tool and file but still infinity box show bad file need to fix this with this pac file |
