09-23-2008, 23:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | Problem speed in pin finder pin ditected wint pin finder ok here log software version: 1.14 cable type: 2x7 (L14B) platform: MT: MT62xx (autodetect) searching adapter at COM4... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed -------------------------------- speed fixed in 19200 CPU: MT6205 result: Rx:9 Tx:2 time required: 57 sec Power On ! with soft infinity all is ok speed selected slowest COM4 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed here again speed in 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 01/01 Initialize Done Set baud... slowest error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 24 sec Remove/Install battery now ! phone no repaired problem speed in pin finder to infinitysupport plz fixe the problem |
09-24-2008, 14:15 | #2 (permalink) | |
Insane Poster Join Date: Jul 2005 Location: Obuasi, Ghana Age: 61
Member: 162536 Status: Offline Thanks Meter: 5 | Quote:
Go to CHINESE MIRACLE software and change speed to any number less than the current speed you are using and your problem will be solved. | |
Plz add this in pin finder | ikkks | Infinity-Box | 2 | 03-14-2009 17:12 |
Problem rectified in Pad Finder | lovingazmee | PadFinder box | 2 | 03-05-2009 16:24 |
problem with my pin finder | tshibano | Infinity-Box | 1 | 07-17-2008 22:43 |
Problem To Active Pin-finder | ABOUSHADY | Infinity-Box | 11 | 02-20-2008 02:42 |
