03-12-2007, 20:01 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: EU Age: 40
Member: 67146 Status: Offline Thanks Meter: 0 | PROBLEM UNLOCK BENQ A38, help I have problem with unlock/flashing A38 I have use infinity cable BENQ M300, I choose COM port, do "SP UNLOCK" and allways after "power on the phone" after few moments its stop on 14% WHY?? On "Read full flash" software after few moments stop too |
03-12-2007, 20:43 | #3 (permalink) |
Member: 67146 Status: Offline Thanks Meter: 0 | sorry for my dubblr topic its log READ FLASH COM15 selected Device: BenQ A38 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... part 1 of 1... Reading... ......................and I can wait 2 hours-nothing will hapened .....after press STOP I see file saved: backup_full_part_1_of_1_20070312-204210.6BX.bin Flash: 0001:227E221D2200 failed Finished, time used: 289 sec Remove/Install battery now ! |
03-12-2007, 20:53 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use different baudrate. and after software write "Reading..." do you see any LEDs blinking ? Also, please, download latest BModule from support area and try again. |
03-12-2007, 21:02 | #5 (permalink) |
Member: 67146 Status: Offline Thanks Meter: 0 | Now I do SP UNLOCK with SUCCESS!! COM15 selected Device: BenQ A38 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0001:227E221D2200 file saved: backup_eeprom-00_20070312-204940.6BF.bin Check Parameters Done Check Space... Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E221D2200 Writing Done Finished, time used: 361 sec Remove/Install battery now ! But-it may take to 361sec ?? Its normal with this baudurate ?? Thanks for help, now I'll take to change lang menu |
03-12-2007, 21:12 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it's big time. Probably ot was errors during reading and software repeat read operation several times. I think it can be problems with cable. Please, if you can, try other cable next time. I am not sure, it's just an idea. |
03-15-2007, 23:53 | #9 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Ghana Age: 43
Member: 171776 Status: Offline Thanks Meter: 17 | hello i have siemens-benq A38 version 1.23 when i call the comminication passe but when we call me it show number busy i tray to flash it with infinity-box and make full reset but nothing please help me infinitysupport |
help problem unlock blackberry 7290 help | nejm | FuriousGold | 2 | 04-26-2010 19:49 |
how to unlock benq A38 | san9090 | Infinity-Box | 8 | 07-27-2009 13:57 |
Problems Unlocking ZV10 Please Help | mbcommunication | NSPRO | 5 | 02-26-2006 23:28 |
Problem unlocking BenQ O2X2 | scorpion13 | FuriouS II | 6 | 11-24-2004 03:13 |
