09-13-2007, 09:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Problem to unlock a Lobster 575? Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Infinity just hangs here? |
09-13-2007, 15:15 | #2 (permalink) |
Member: 307549 Status: Offline Thanks Meter: 188 | Now im getting this COM13 selected Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20070913-142901.92E.bin please, wait... pass-1... pass-2... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E22022201 Err: answer#00 try#1 to recover write error at 01C50000 Err: error checksum try#2 to recover write error at 01C50000 Err: answer#96 try#3 to recover write error at 01C50000 Err: answer#B4 try#4 to recover write error at 01C50000 Err: answer#20 try#5 to recover write error at 01C50000 Err: answer#12 try#6 to recover write error at 01C50000 Err: answer#1F try#1 to recover write error at 01C52000 Err: answer#13 try#2 to recover write error at 01C52000 Err: answer#00 try#3 to recover write error at 01C52000 Err: answer#01 try#4 to recover write error at 01C52000 Err: answer#22 try#5 to recover write error at 01C52000 Err: answer#02 try#6 to recover write error at 01C52000 Err: answer#22 try#1 to recover write error at 01C54000 Err: answer#01 try#2 to recover write error at 01C54000 Err: answer#22 try#3 to recover write error at 01C54000 Err: answer#96 try#4 to recover write error at 01C54000 Err: answer#B4 try#5 to recover write error at 01C54000 Err: answer#20 try#6 to recover write error at 01C54000 Err: answer#12 try#1 to recover write error at 01C56000 Err: answer#1F try#2 to recover write error at 01C56000 Err: answer#96 try#3 to recover write error at 01C56000 Err: answer#B4 try#4 to recover write error at 01C56000 Err: answer#20 try#5 to recover write error at 01C56000 Err: answer#12 try#6 to recover write error at 01C56000 Err: answer#1F try#1 to recover write error at 01C58000 Err: answer#00 try#2 to recover write error at 01C58000 Err: answer#00 try#3 to recover write error at 01C58000 Err: answer#00 try#4 to recover write error at 01C58000 Err: answer#00 try#5 to recover write error at 01C58000 Err: answer#00 try#6 to recover write error at 01C58000 Err: answer#00 try#1 to recover write error at 01C5A000 Err: answer#00 try#2 to recover write error at 01C5A000 Err: answer#00 try#3 to recover write error at 01C5A000 Err: answer#00 try#4 to recover write error at 01C5A000 Err: answer#00 try#5 to recover write error at 01C5A000 Err: answer#00 try#6 to recover write error at 01C5A000 Err: answer#00 try#1 to recover write error at 01C5C000 Err: answer#00 try#2 to recover write error at 01C5C000 Err: answer#00 try#3 to recover write error at 01C5C000 Err: answer#00 try#4 to recover write error at 01C5C000 Err: answer#00 try#5 to recover write error at 01C5C000 Err: answer#00 try#6 to recover write error at 01C5C000 Err: answer#00 try#1 to recover write error at 01C5E000 Err: answer#00 try#2 to recover write error at 01C5E000 Err: answer#00 try#3 to recover write error at 01C5E000 Err: answer#00 try#4 to recover write error at 01C5E000 Err: answer#00 try#5 to recover write error at 01C5E000 Err: answer#00 try#6 to recover write error at 01C5E000 Writing Fail |
09-14-2007, 08:02 | #4 (permalink) |
Member: 307549 Status: Offline Thanks Meter: 188 | Now with power supply on the phone i get this but the phone is still locked COM13 selected Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20070914-075952.92E.bin please, wait... Err: not locked or unknown eeprom Check Data Fail Finished, time used: 755 sec Remove/Install battery now ! I cant see a Eprom either in the support area? How can this be fixed? |
09-14-2007, 14:48 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Are you sure that your phone has sp-lock but not user code lock ? We will prepare repair eerom files ASAP. Also, please, read flash from your phone and send to [email protected] |
09-14-2007, 17:23 | #6 (permalink) | |
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
Yes this phone is 100% sp locked. Reading flash now. | |
09-14-2007, 18:32 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Repair eeprom files for Lobster-575 uploaded in support area. Make eeprom backup from your phone and you can try to use repair eeprom files. |
10-22-2007, 15:11 | #8 (permalink) |
Freak Poster Join Date: Sep 2003 Location: france
Member: 38884 Status: Offline Thanks Meter: 44 | COM4 [VCP2] selected Device: Lobster 575 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20071022-155431.92E.bin please, wait... pass-1... pass-2... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E22022201 Writing Done Finished, time used: 166 sec Remove/Install battery now ! |
Problem to Unlock Samsung I450. I enter code OK, but Not Unlock [SOLVED] | Grupo MovilFree | PolarBox 3 | 2 | 03-11-2010 12:15 |
Problem to Unlock Samsung E250v.Canīt see codes and unlock directly ::: SOLVED ::: | Grupo MovilFree | PolarBox 3 | 9 | 09-06-2009 14:37 |
Problem to Unlock SE P1i with D unlocker -Unknown server problem [129] | ahsotelo | D-Unlock Suite | 1 | 04-24-2009 13:45 |
Problem to unlock one w910 stop to authenticate 1 success ? | gsmnice | Seking Server | 1 | 09-15-2008 03:18 |
If you have any problems to unlock your user code on X35 ---> Read this ! | cyber6 | x1x to x45/x50 | 6 | 09-02-2001 23:53 |
