09-14-2011, 23:09 | #1 (permalink) |
Temporary banned !! Join Date: Jul 2007
Member: 555091 Status: Offline Thanks Meter: 10 | problem in unlock messengr edition 261 by sfr a try but not success COM4 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X930_V1_Z2_FRES_B1EF105 Version: MB3508AV1BMB_BV1.0 ==================== New firmware found (v.4.01, database date: 19.08.2011): X930_V1_Z2_FRES_B1EF105 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 0 1 2 3 4 6 7 8 9 10 11 12 13 15 21 22 23 24 25 27 28warning: wrong packet cs 29 30 31 32 33 34 36error: detection failed (28 tries), read flash and send to support connection Ok detecting structure #1... 1 3 4 6 7 11 14 16 18 19 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 1 min 38 sec Remove/Install battery now ! a try other method but not supported method is not supported yet this is full flash: messengr edition 261 by sfrZTEMT35_09B_PCB01_GPRS_MT6235B_S01.X930_V1_Z2_F RES_B1EF105.BIN_FLNH8ACS0PE0MBR_46M_C__fullflash_2 0110911-004137.B4M.rar - 4shared.com - online file sharing and storage - download |
09-17-2011, 12:08 | #3 (permalink) | |
You must select correct model in software ! What is the results now ? | |
09-17-2011, 15:46 | #4 (permalink) |
Member: 555091 Status: Offline Thanks Meter: 10 | COM4 [VCP0] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 11 sec Remove/Install battery now ! COM4 [VCP0] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot Off chip: 0000:0000:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! COM4 [VCP0] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 22 sec Remove/Install battery now ! |
09-17-2011, 16:03 | #5 (permalink) |
Member: 555091 Status: Offline Thanks Meter: 10 | COM4 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X930_V1_Z2_FRES_B1EF105 Version: MB3508AV1BMB_BV1.0 ==================== New firmware found (v.4.01, database date: 19.08.2011): X930_V1_Z2_FRES_B1EF105 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 0 1 2 3 4 6 7 8 9 10 11 12 13 15 21 22 23 24 25 27 28warning: wrong packet cs 29 30 31 32 33 34 36error: detection failed (28 tries), read flash and send to support connection Ok detecting structure #1... 1 3 4 6 7 11 14 16 18 19 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39error: detection failed (29 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 1 min 42 sec Remove/Install battery now ! |
09-17-2011, 16:19 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Still you have selected wrong model. Select SFR-261 from model list or when MModule v4.01 opens just go to "Settings" tab click on "Model" list and manually select SFR-261 model and then repeat the process. Should be like this- COM3 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: SFR-261 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! Wr. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-17-2011, 17:54 | #7 (permalink) |
Member: 555091 Status: Offline Thanks Meter: 10 | unlock ok thx for all I am a new user lol COM4 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: SFR-261 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X930_V1_Z2_FRES_B1EF105 Version: MB3508AV1BMB_BV1.0 ==================== New firmware found (v.4.01, database date: 19.08.2011): X930_V1_Z2_FRES_B1EF105 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 115 byte(s) read imei: 35275904014234 connection Ok 216 byte(s) read reading data... reading data #2... building new data... writing data... 204 byte(s) read reading data... 264 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 19 sec Remove/Install battery now ! |
