12-31-2005, 00:46 | #1 (permalink) |
Insane Poster Join Date: May 2005 Location: Sweden Age: 54
Member: 148505 Status: Offline Thanks Meter: 0 | Problem with unlock Vs3 Please i have problem with unlock Panasonic Vs3. I update my Infinity box today to be able to unlock Vs3. I follow the instruction for unlock and the program give me the unlock code when i inter onther sim card not vodafone which was locked to it was working no problem so i thinked that its direct unlock but after some time 2 hours maybe i insert onther sim card for onther operator it was not working i try to but the code to unlock the phone it say code not right, i put the other code the same not right code please help me here is the Log. Log opened: [31/12/2005] [07:30:31 م] App: D:\Documents and Settings\El Moursi\Desktop\New Infinity\Pana01_v116\Pana01.exe [Infinity Box] v.1.16A Loading, wait... S/N: 01E2:0105 Wait... Current device: X60,X66,X68 Ready Current device: VS2,VS3 COM14 ready Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356404000315568 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.01SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS3-VA43,Jul2200521:52:17 Found: Network Found: Sub-network Unlock code: 06363582 Unlock code: 06473684 EXACTLY STEP-BY-STEP: 1. insert ANY sim-card into phone 2. switch-on phone 3. switch-off phone 4. switch-on phone, press 52824** 5. enter unlock code 6. switch-off phone Done Finished Now when i try to unlock the phone it gives me this log ---------------- Log opened: [01/01/2006] [01:22:51 ص] App: D:\Documents and Settings\El Moursi\Desktop\New Infinity\Pana01_v116\Pana01.exe [Infinity Box] v.1.16A Loading, wait... S/N: 01E2:0105 Wait... Current device: X60,X66,X68 Ready Current device: VS2,VS3 Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356404000315568 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.01SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS3-VA43,Jul2200521:52:17 In progress[EEP01_356404000315568]... In progress[EEP02_356404000315568]... Found: Sub-network No active locks found Done Finished Please help me to fix this problem, i fix onther one it was the same but i fix it its accept the code and be unlocked its locked to vodafone Sweden, How to read flash please? and how to inter the code i mean shall i click 3 to put the net code? i did all of them i clicked from 1-6 and put the code not accepted in 3 and 4 wrong code. Thanks best Infinity team support |
12-31-2005, 12:24 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Badajoz Age: 45
Member: 132858 Status: Offline Thanks Meter: 1 | Hi, i have the same problem with one Vs3. After unlock it only works with one operator ( not the original ) , the others says " not valid sim ". Well, then I try to enter unlock code, but i have some doubts, because the phone itīs still blocked: 1) . insert ANY sim-card into phone; The sim card is into the phone during all process? 2) After press 52824** must i press call key or ok? 3) After insert unlock code must i press ok or call key? Thank you |
12-31-2005, 15:55 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Moursi Are you sure that phone is sim-locked now ? If you really sure, make unlock again and make "Unlock in any case" box checked. @Borjina Please, follow the instruction that you will see in software log window after unlock process EXACTLY step by step. 1) ANY sim card means: ANY sim card. that was inserted during unlock, that was not inserted, any other sim card that you can find. 2) you need to press nothing after you press last **. You will see SIM-LOC MENU. no need to press anything else. just use up/down arrows to find lock that closed in your phone 3) Do you want to make a call during unlock process ? If yes, you can try to press CALL button, but i think taht call wil be failed. So pls, just press OK button |
12-31-2005, 16:43 | #4 (permalink) |
Member: 132858 Status: Offline Thanks Meter: 1 | Well, i think my mistake was not to insert any simcard during the unlock ( via cable ) function. I thougth that was after unlocking progress for typing the secuence..... Thereīs no need to use sarcasm, obviously i donīt need to make a phone call, but when i do step by step these secuences the phone stay like nothing happend, thas was may question, nothing more..... |
01-01-2006, 18:11 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Actually, there is no any difference for unlock process with inserted or not inserted sim card. It's a fact for 99% of phone unlocking operations (some methods need that SIM card should be inserted but last time it's quite rare situation). so, if you don't see special instruction at start, you can make unlock with or w/o sim-card inserted. It's not important. For VS unlock we have prepared small instruction and I thought that it have to be not so hard for users to read this text in capital letters: "EXACTLY STEP-BY-STEP:" And you can't imagine how many people don't like to read simple instructions. btw, how is final unlock result ? |
01-02-2006, 10:19 | #6 (permalink) |
Member: 132858 Status: Offline Thanks Meter: 1 | I know, but i read all the documentation about vs3 in the pana v 1.15, and i did it exactly, my doubt was then, when i typed the secuence written in the soft. In a few hours iīll post resoults. Regards |
01-02-2006, 19:13 | #10 (permalink) |
Member: 132858 Status: Offline Thanks Meter: 1 | Sure, i never told you that soft doesnīt work, just asked how itīw works propertly.... i donīt understand very well the steps. only this... REGARDS EVERYBODY HAPPY NEW YEAR |
02-26-2006, 19:32 | #11 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL
Member: 60081 Status: Offline Thanks Meter: 9 | me too can t unlock vs3 Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356404002684219 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.01.01SMARTI_SDB1SGOLDlit MMI ver: Mmi:VS3-VA49,Sep22200510:43:49 In progress[eeprom-01_356404002684219]... In progress[eeprom-02_356404002684219]... Found: Network Err: unlock not possible[01] Done Finished |
02-26-2006, 19:39 | #12 (permalink) | |
Pls, read flash from this phone and send to: [email protected] we will check what is wrong ASAP. | |
03-30-2006, 10:57 | #14 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Sun12:\\Earth Age: 45
Member: 123931 Status: Offline Thanks Meter: 0 | Quote:
03-30-2006, 12:33 | #15 (permalink) | |
The Best link here: http://forum.gsmhosting.com/vbb/show...9&postcount=38 As about your problem: 1. make "Unlock in any case" box checked. 2. press "Unlock" button again 3. make final unlock procedure exactly like described in software log window. the most important word is: exactly. No need to skip any step even if you think that it's not important step. | |
I have Problem With sagem VS3 | Mierdita | SAGEM JTAG UNLOCKER | 11 | 12-26-2006 15:29 |
i have problem with unlock k608i i try with version 7.10 | gsm4libya | Cruiser Suite | 9 | 12-12-2005 10:23 |
Problem with unlocking X70 with panaufo | azizraza | Panasonic | 0 | 05-25-2005 14:05 |
problem with unlocking with 2.3 reader | Destructor | ARM9 BASED M62 / M62+ | 5 | 02-29-2004 22:20 |
