04-11-2008, 21:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 702472 Status: Offline Thanks Meter: 18 | strangle second sim pb gsm people somebody show some soluytion about this pb? After format operation N95 2sim the secxond sim can't release call again.I mean that I can't cut call with sim number two Tell me what to do best regard |
04-12-2008, 10:44 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please explane more detailed: which phone parts you formatted, what formating method and in which sequece (which one you formatted first, which second) |
04-12-2008, 18:17 | #3 (permalink) |
Member: 702472 Status: Offline Thanks Meter: 18 | I do safe format for the first mcu 6226 I try the complet but no match the pinout is 3-rx 5-tx 6-gnd but i can't the secon mcu i try the pinout 2 rx 4tx but no answer the connector is 2....6 mini |
04-12-2008, 20:42 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you must find proper pinout for second MCU. i can advice you to exclude from search pins : 3,5,6 and on all others measure volatge. second CPu pins will have voltage near 2,7-2,8 volts after you get connection- format second part and restore IMEI if needed |
04-16-2008, 17:08 | #15 (permalink) |
Member: 702472 Status: Offline Thanks Meter: 18 | I TRY General mobile file and the phone on but the keypad is not the same then i put an other mtk26 and my phone on the pb of releasing is till there again i mean i can make call with 2 sim but i can't cut it i will return it to the owner thank for your help |
3660 insert sim pb pls help??? | proxy_gsm | WD2 & APE (Symbian Phones) | 8 | 09-10-2011 11:03 |
j600e insert sim pb | mehdi123 | Samsung Hardware Repair | 1 | 11-13-2008 18:09 |
sim verrou without sim pb | broda | SMTi | 2 | 10-21-2008 18:52 |
---trend t500 dual sim second sim is not working any solution--- | makkah mobile | Infinity-Box | 1 | 09-12-2008 09:26 |
Motorola V60i insert sim pb pls help??? | proxy_gsm | Motorola P2k | 3 | 01-06-2004 09:09 |
