Old 09-29-2010, 12:19   #1 (permalink)
ace_venturia's Avatar
Member: 260236
Sonork: 100.1641081
Thanks Meter: 135
Problem in unlock ZTE G-N281
@ Infinity team
Problem with unlocking zte g-n281 miami..
firmware read succesfull but no unlock
firmware: ZTE-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ ENG_EN_P107A3V1_0_8B05__firmware_20100929-163731.B4M
locked to Orange, USA
urgent help needed
Old 09-29-2010, 12:20   #2 (permalink)
atiq022's Avatar
Member: 587405
Sonork: 100.1681610
Thanks Meter: 151
sned imeil i will give u unlock code
Old 09-29-2010, 12:23   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Originally Posted by ace_venturia View Post
@ Infinity team
urgent help needed
pls post opration logs then i will procedure
Old 09-29-2010, 21:54   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@ Infinity team
urgent help needed
Hello,
What is the problem with unlock exactly ?
Post here operation log.
Also, it may be that forr unlock you have to use pinout (Rx/Tx/Gnd) via test-points under battery, but not via phone bottom connector.
Old 11-03-2010, 08:56   #5 (permalink)
Member: 260236
Sonork: 100.1641081
Thanks Meter: 135
COM23 [VCP0] selected
module v3.51
Action: read unlock codes
unlock method: read codes
Model: ZTE-N281
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
error: operation failed !
Finished, time used: 1 min 39 sec
Remove/Install battery now !
Old 11-03-2010, 09:32   #6 (permalink)
Member: 260236
Sonork: 100.1641081
Thanks Meter: 135
solution found..thx to aslam 870
http://forum.gsmhosting.com/vbb/f296...miami-1026022/
The Following 2 Users Say Thank You to ace_venturia For This Useful Post:
Old 11-03-2010, 09:32   #7 (permalink)
Member: 153893
Thanks Meter: 266
module v3.51
Model: ZTE-N281
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
friend try to hold the power button till it tells u so to remove ur hand and it well unlocked.
gudluck
The Following User Says Thank You to godwin For This Useful Post:
Old 01-07-2011, 15:46   #8 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
pls try this my post after see you will gets some ideas from ithttp://forum.gsmhosting.com/vbb/6141171-post2922.html
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Page generated in 0.19544 seconds with 9 queries
