Old 01-09-2010, 11:39   #1 (permalink)
mohamedsamir_04's Avatar
Member: 689226
Thanks Meter: 58
problem with vodafone 226
hi ininity team i have
vodafone 226/ax2007cs2
f273/08 n1
dont be unlocked with my infinity box
and here is the log
module v1.72
Device: Sagem-my226
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
e-gold: 820010
loading...
error: can't run preloader: 01
middle part...
error: can't run middle loader: 0802
Finished, time used: 21 sec
Remove/Install battery now !
the phone when i releass he power power on and he dont termenate the boot operation is thereany soloution ?
Old 01-11-2010, 17:44   #2 (permalink)
Member: 689226
Thanks Meter: 58
what s up infinity team there is no one to give me help.????????????????????????!!!!!!!!!!!!!!!!!!!!! !!!!????????
Old 01-11-2010, 19:48   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to use ordinary COM port cable instead of Unibox.
Old 04-19-2010, 13:52   #4 (permalink)
Member: 201764
Thanks Meter: 76
Originally Posted by InfinitySupport View Post
Hello,
Be more explicity please ,because we begginers are more slowly
Old 04-20-2010, 12:21   #5 (permalink)
Member: 1043909
Thanks Meter: 60,926
For now you have box (so called Unibox with FT232 chip inside) that connected to PC USB port via usb cable.
Inside box located so called "usb-rs232 converter".
This "converter" create in your PC system so called "virtual COM port".
So for now you use that so called "virtual COM port" instead of genuine COM port.
In some cases it's better to use genuine COM port (or another virtual COM port type) instead of virtual com port.
So I make an offer to you: if you have a problems with connection you can try to use other cable, f.e. cable based on another "usb-rs232 converter type", f.e. so called "Prolific" converter.
Also you can use try to use genuine COM port.
Also, you can try to adjust port settings:
p.s.
if you did not understand an advice in my first message well I strongly suggest you to learn about cables/phones, about Rx.Tx etc. so in several years of hard work you will be able to be the real professional.
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Problem with Vodafone 226 unlock caponord Infinity-Box 6 01-08-2009 21:34
problem unlock vodafone 226 krimmo Infinity-Box 6 09-17-2008 23:20
Problem with vod 226 Nylus PolarBox 3 7 05-20-2008 01:57
Charging problems with vodafone 802se Berstav Sony Ericsson Hardware Repair 0 06-14-2006 09:37
Problem with vodafone new simcards Nylus Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 07-21-2003 20:01
Page generated in 0.15146 seconds with 10 queries
