01-26-2008, 01:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: romania
Member: 201764 Status: Offline Thanks Meter: 76 | problem whit lg kg 290 Dear friends ,somme customer have bring me that phone because when the phone is start on the screen appears only LG KG290,and dont wanna started (he closed back).I was try to flash it whit only 2 software in the support area,but after writing firmware ,program stopped to write anymore ,and he show me somme error: COM34 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456012826999 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601282699 9_LG KG290_20080126-021747.B1E.bin . . . . . . . . . . . . . . Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail error: wrong answer[C5] Finished, time used: 1775 sec Remove/Install battery now ! What shud i do whit this phone? Thanks |
02-29-2008, 20:32 | #3 (permalink) |
Freak Poster Join Date: Oct 2004 Location: UK
Member: 89109 Status: Offline Thanks Meter: 8 | why would they post something on the support forum which wont even fix ur fones and instead will Fuk it up dang... hope they would realize it and post some working flashes so atleast we can put phone back to its actual state which customers brought wiv.. would someone please post some workin flash files hea.. thanks... |
03-02-2008, 18:55 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you very much for your patience ! To be honest I am really proud that people always compare Infinity-Box (multibrand tool) with with other tools that was produced for selected brands (and this comparison not always so bad for us as you can think). Also I and glad to see that people become surpriced if they don't get updated software from Infinity-Box team in 1 day after they report about bugs. This means that ordinary we work very fast If you still have problems with flashing, please, try to use our latest Lg update: http://67.15.194.130/vbb/showthread.php?t=508247 It was made some fixes and I hope that now everything should be fine. Please, post here any comments and reports (so detailed as possible), so in case of any problems we can help you ASAP. |
04-08-2008, 16:06 | #8 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Ketchery Bazar FSD Pakistan Age: 49
Member: 135718 Status: Offline Thanks Meter: 5 | kg290 show logo on screen and then goes off or restart i change imei flash code data and alchemydata thn unlock but its still same whn i try to flash it wid infinity box it says flash write error confused here |
04-08-2008, 17:45 | #10 (permalink) |
Member: 135718 Status: Offline Thanks Meter: 5 | here is log : COM4 selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 357456012407089 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601240708 9_LG KG290_20080408-214349.B1E.bin .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 89881600010001:89881600000000 error: wrong answer: B1 error: flash write error: 01B60000:00020000 error: no any expected answer error: flash write error: 01B60000:00020000 Write Fail Finished, time used: 95 sec Remove/Install battery now ! |
04-08-2008, 17:49 | #11 (permalink) |
Member: 135718 Status: Offline Thanks Meter: 5 | i flash it wid hwk twice and imei was crupt i chnage imei wid hwk imei okey now bt after flash its stuck onlg logo and then sleep or some time blinking dnt have back up coz some one els unlock it wid infinty or some other soft ,customer gives whn it was restarting . |
04-08-2008, 23:43 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Use this software: http://www.infinity-box.biz/download/public/LGA.rar flash phone again (code + alchemy) and post log here. |
04-12-2008, 01:02 | #15 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | thanks infinity teamm but same COM1 [Serial0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: ************* file saved: C:\Documents and Settings\Raj\Desktop\LGA\backup_eeprom_*********** **_LG KG290_20080412-052954.B1E.bin ........................................... Check flash Done Check space... current eeprom imei: ************** ....................................... finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done error: wrong answer: C4 Finished, time used: 79 sec Remove/Install battery now ! |
LG KG 290 Imei change problem please help | rashidrasheed81 | Infinity-Box | 4 | 02-13-2010 14:23 |
lg kg 290 Big problem | ajila | Infinity-Box | 1 | 05-29-2009 11:56 |
lg kg 290 problem after change imei | prime_master786 | Infinity-Box | 4 | 03-06-2009 15:29 |
lg kg 290 problem after change imei | prime_master786 | HWK | 1 | 03-05-2009 18:10 |
successfully unlocked LG KG 290 | mujahid_ali | Infinity-Box | 7 | 02-27-2008 09:48 |
