Old 02-20-2008, 21:00   #1 (permalink)
Member: 644590
Thanks Meter: 4
Angry problem writing Alchemy data for KG290
my phone is dead after flashing with my infinity box there is the log
COM31 [VCP0] selected
Device: LG KG290
Checking data, wait...
Action: flash write
Skip: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"keep calibration" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 357456012407089
file saved: backup_eeprom_357456012407089_LG KG290_20080220-205025.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Alchemy data
flash: 90009000900090:90909000000000
error: wrong write first sector at 0x00000000
Write Fail
error: wrong answer[C5]
Finished, time used: 25 sec
Remove/Install battery now !
the battery is full charging and my phone befor flashing have a restart problem with sim inside
please need help
Old 02-21-2008, 04:10   #2 (permalink)
Member: 712108
seems to be a flash ic problem, somes data address cant be writed, try rehot the flash ic.
good luck
Old 02-21-2008, 09:06   #3 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
this is bug in soft you need to erase hwk and full repair file flash with FG
br
maplegsm (umer)
Old 02-27-2008, 17:35   #4 (permalink)
faysal's Avatar
Member: 89109
Thanks Meter: 8
DOn't think its anything to do with hardware
cause fone was ok without memory card but with memory card it was comin white lcd..
I tried to flash this kg290 and fones stuck on white lcd or kg290 display logo..
wot solution would be handy?
I m tryin to download files for vygis n ufsxhwk aswell.. if i would be able to fix it I would post my log hea..
If someone please know the exact procedure to get rid of this problemo please do post ur reply hea..
thanks..
Old 03-01-2008, 17:46   #5 (permalink)
faysal's Avatar
Member: 89109
Thanks Meter: 8
fixed it finally..
wiv Vygis ofcourse ..
took around 15 mins to flash unlike infinity...
neway Ramziii if u wan to get it fixed u got to use vygis or wait until infinity uploads some flash files on support forum..
cheers...
Old 03-02-2008, 18:55   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Thank you very much for your patience !
To be honest I am really proud that people always compare Infinity-Box (multibrand tool) with with other tools that was produced for selected brands (and this comparison not always so bad for us as you can think).
Also I and glad to see that people become surpriced if they don't get updated software from Infinity-Box team in 1 day after they report about bugs. This means that ordinary we work very fast
If you still have problems with flashing, please, try to use our latest Lg update: http://67.15.194.130/vbb/showthread.php?t=508247
It was made some fixes and I hope that now everything should be fine.
Please, post here any comments and reports (so detailed as possible), so in case of any problems we can help you ASAP.
Old 03-02-2009, 14:42   #7 (permalink)
Member: 130995
@dbhakta
Your offtopic message was deleted. Here is Infinity-Box support forum but not discussion about anything else.
Please next time select correct forum section.
Old 03-02-2009, 17:10   #8 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Device: LG KG290
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Alchemy data
Write Fail
please need help
Bro i had the same problem,,,,,do the following
1. Flash with Old version u have revive fone but it could be the same problem which u had last.
2. just reset settings n u have fully worked fone it is test by me 2 sets 276 n 290 same problem,,,,BR
Old 04-18-2009, 07:11   #9 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
kg290 write error problem solved
hi every body
just install the old version of lga v1.22 or v1.24
and flash it with KG290P40-ESA-V10a-000-00_Sep-07-2007_code_alchemy.B1M.bin
which is located in support area
wbr
shahab mobiles
The Following User Says Thank You to shahabuddin For This Useful Post:
Old 04-18-2009, 11:05   #10 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
wats problem wth kg290 i got 1 other kg290 with same problem which is not solve wth
KG290P40-ESA-V10a-000-00_Sep-07-2007_code_alchemy.B1M.bin. it got probly error and set show
only logo. and give error wth alchemy
Here is logo
COM6 [VCP0] selected
Device: LG KG290
advanced flash detection active
Action: flash write
Skip: File system
Write: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 350305260000001
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KG290_20090418-150253.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Alchemy data
Write Fail
Finished, time used: 91 sec
Old 04-19-2009, 08:20   #11 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
solved problem of kg290 today step by step
finally solved the problem of lg kg290 show only logo and write error
for writing error use LGA v1.24 flash with any version for kg290. problem will
solved. if set become only show the logo then of then download the latest version of LGA v1.38 and flash it with
the problem is solved which is tested by me 100%. if any one have still problem post me loge and result
here is logo
module v1.37
Device: LG-KG290
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
"keep calibration" active
Boot ...
Connecting, wait...
Release Power button now !
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
file saved: C:\Program Files\InfinityBox\LGA\New Folder\eeprom_350305260000001_LG-KG290_20090419-112008.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Erase ...
Erase Done
Write ...
calibration area skipped
write: 2nd chip area
Write Done
Finished, time used: 2775 sec
The Following 3 Users Say Thank You to shahabuddin For This Useful Post:
Old 08-13-2009, 17:39   #12 (permalink)
mk_17's Avatar
Member: 326512
Thanks Meter: 27
i try all kg 290 in internet nothing work i'm now will try another model may work
or no MR.infinity
plz reply
6301b Writing SIMLOCK DATA and SIMLOCK DATA KEY... Failed... dhanrhage_24 Nokia Base Band 5 ( BB-5 ) 0 05-12-2009 06:43
Polish lang for KG290 for Vygis? fingusio VygisToolbox 0 12-19-2007 19:36
Press yes to write simlock data from file to phone... NOW 6300 10/10 Uvedovle MT-BOX 8 09-27-2007 19:30
cf62 writing simlock data failed!!!!!! kamo44 E-Gold Based Phones 1 01-22-2006 16:40
Page generated in 0.28139 seconds with 10 queries
