08-14-2009, 20:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | problem zonda 1075 phone its mt6225 based cpu the original flash from phone was Zonda-1075-SL399_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_36_MP_V23_F1_En_Es.B0M.bin i try to unlock the phone and always have a mesage uknow eprom i try to unlock using 1075 model too but fail so i try to flash the phone with the flash from support and try to unlock after now the phone doesnt turn on and i try to flash as zonda 1075 and zmem 1075 with mt6226 and mt 6225 flashes but fail i dont read the original flash from phone because i never had any problems with zonda phones also after flash with the original flash from phone ( Zonda-1075-SL399_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_36_MP_V23_F1_En_Es.B0M.bin ) from support i try repairing trought repair security area option and phone its still dead what can i do ? |
08-14-2009, 21:10 | #2 (permalink) |
Member: 103024 Status: Offline Thanks Meter: 616 | problem solved problem solved by erasing whole flash chip and flash original flash again also repaired security area after all prosess and keep presed power button for a 1 minute aprox lol but phone cannot be unlocked yet here is the log COM1 [VCP0] selected module v2.83 Device: Zonda-1075-SL399R-ZMEM1075 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:BE03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 6_MP_V23_F1.BIN ver. sw 2: MAUI.07A.W07.36.MP.V23.F1, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Zonda-1075-SL399R-ZMEM1075_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_ 07A_W07_36_MP_V23_F1__ffs... file saved: C:\Documents and Settings\roger_server\Escritorio\Zonda-1075-SL399R-ZMEM1075_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_ 07A_W07_36_MP_V23_F1__ffs_20090814-030850.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 99 sec Remove/Install battery now ! |
08-14-2009, 21:15 | #3 (permalink) |
Member: 103024 Status: Offline Thanks Meter: 616 | here is the other log here is the other log trying to unlock as zonda 1075 COM1 [VCP0] selected module v2.83 Device: Zonda-1075-SL399 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:BE03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 6_MP_V23_F1.BIN ver. sw 2: MAUI.07A.W07.36.MP.V23.F1, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Zonda-1075-SL399_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_36_MP_V23_F1__ffs... file saved: C:\Documents and Settings\roger_server\Escritorio\Zonda-1075-SL399_SL399G_TELCEL_PCB01_GPRS_MT6225_S00.MAUI_07A _W07_36_MP_V23_F1__ffs_20090814-031406.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 97 sec Remove/Install battery now ! |
Zonda Zmem 1075 problem | rogerboogie | Infinity-Box | 1 | 12-02-2009 05:26 |
15 Jul 2008: LG-KP220, Zonda-1075, Zonda-1085, MyPhone-S21 models under test | InfinitySupport | Infinity-Box | 40 | 09-26-2009 00:57 |
ZONDA 1075, 1085,1090,1095 unlock never work | cordd | Infinity-Box | 1 | 11-16-2008 10:21 |
zonda 1075 unlock fail | cordd | Infinity-Box | 2 | 09-12-2008 22:19 |
unlock zonda 1075 | cordd | Infinity-Box | 1 | 07-06-2008 16:23 |
