12-17-2007, 21:32 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: AL-ZAIM TELECOM -ALGERIA Age: 52
Member: 59797 Status: Offline Thanks Meter: 76 | N95 IMEI reset to 13xxxxx each time I have a problem which occur always with N95 Chinese. After FFS forman and IMEI set to 35xxxx-00-xxxxxx-x and if I try to take a snapshot with camera, the IMEI goes immediately to 13xxxx-xx-xxxxxx-x which is not supported by our networks. Anyone have a solution to this? Systemlog is attached to know for which FW I'm talking. BR |
12-17-2007, 21:34 | #2 (permalink) |
Member: 59797 Status: Offline Thanks Meter: 76 | N95 IMEI re-set to 13xxxx alone Hi all. I have a problem which occur always with N95 Chinese. After FFS forman and IMEI set to 35xxxx-00-xxxxxx-x and if I try to take a snapshot with camera, the IMEI goes immediately to 13xxxx-xx-xxxxxx-x which is not supported by our networks. Anyone have a solution to this? Systemlog is attached to know for which FW I'm talking. BR |
12-17-2007, 21:40 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | it is not INFINITY prob or software prob but phone prob . I have already seen the same problem for some CM but i solve it with COMPLETE FORMAT not SAFE FORMAT , and sometimes if phone have bad or corrupted firmware just FULL FLASH it and FORMAT it again and repair IMEI . good luck |
12-17-2007, 23:41 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 55
Member: 60178 Status: Offline Thanks Meter: 30 | HI Mr allal or sid ali i have the same i try with COMPLETE FORMAT after that i flash with full flash always IMEI goes immediately to 13xxxx-xx-xxxxxx-x which is not supported by our networks.i think that is hard |
12-17-2007, 23:53 | #5 (permalink) |
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | @nekbil as i said to MR simplex , this prob is 100% from phone software(firmware corrupted or bad data etc..) and i fix it many times only with complete format or full flash then format and repair imei tested on N95 PDA/ N95 SLIDING UP / N95 SLIDING UP-DOWN/N95 Penguin "i LOVE U VERSION" / and some others CM like N73 /CECT ETC.....but Especially on the N95 because we have received most of them here in Algeria . |
12-18-2007, 00:22 | #6 (permalink) |
Member: 60178 Status: Offline Thanks Meter: 30 | yes Mr allal i try with 10 N95 Penguin "i LOVE U VERSION'' complete format and full flash then format and repairs imei after 2 days the customer come back with the phones the IMEI goes to 13xxxx-xx-xxxxxx-x which are not supported by our networks. very rhanks for you replay |
12-18-2007, 08:42 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | One more reason why Imei may be damaged after phone usega: damaged phone hardware (damaged or bad soldered flash chip), so it's good idea to reball flash chip |
12-19-2007, 22:09 | #9 (permalink) | |
Registered User Join Date: Apr 2004 Location: paradise Age: 45
Member: 60836 Status: Offline Thanks Meter: 4 | Quote:
and what about second sim becaus i can repair only first imei i have alot of ps with second sim bared. can't make call | |
12-20-2007, 14:40 | #10 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Bro i have many chinese phones in Hand ..like i have almost chked all the IMEI when readed with infinty soft it shows it like 135........X...... but never had the problem of network......... |
12-20-2007, 14:55 | #11 (permalink) |
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | @BhattiMobilfone imei prob give network prob for some country on some network not for all . f.e here in my country (algeria) we have 3 operator 603-01 MOBILIS imei >> 135xxxxxxxx no network u get emergency only or sim error. 603-02 DJEZZY imei >> 135xxxxxxxx no network u get emergency only or sim error. 603-03 NEDJMA imei >> 135xxxxxxxx network ok and all is fine. u see where is a problem now ??? br |
12-20-2007, 19:55 | #13 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Setif ALGERIA Age: 44
Member: 80990 Status: Offline Sonork: 100.1583974 Thanks Meter: 312 | @allal123: Do you know what is the difference between "Safe" and "Complete" format processes? Even with complete FFS format and IMEI re-set to 35xxxx the problem occurs IMMEDIATELY if customer tries to get a picture with camera or transfer a file with Bluetooth. Sorry to say this, but your reply has nosense brother, till all N95 "I love U versions" have the SAME problems. I think someone should give a sample to Infinity Support for testing. BR |
12-20-2007, 20:20 | #14 (permalink) | |
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | Quote:
ok my friend i give u one answer and u find the second answer from infinity team 1- may be you can't but i can solv all CM prob with my infinity box format fs in Safe or Complete mode then i repair IMEI if customer return after some days or in the same days . i reflash the phone and repair security area and re write original imei . and all is ok . i dont think it's hard to fix this prob caused with camera or bluetooth .......all this is 99% software prob and 1% is hardware prob ........dont need to send one of this carp to infinity team for test . cause infinity team have all secret and issue for this device from long time . and u know it and u see it like me .. 2- i have multibox/xintel/mtk/free soft, but i work only with infinity box . more info about CM just make one visit and u know where i live and we speak about it clearly br | |
05-01-2008, 11:12 | #15 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | Quote:
Write with the MT- BOX 3230,6260,7610 can't write to finish till the last each time | xuangewen | MT-BOX | 4 | 04-25-2006 19:25 |
is any one here check if is d/l resets to 0 each month ? | cellularman | SonyEricsson (USB-Smart) | 10 | 01-17-2006 14:44 |
my N-Gage's Date and Time always reset each time I removed the Battery | rwinz | WD2 & APE (Symbian Phones) | 5 | 05-13-2005 16:32 |
Samsung Q100-Q105-Q200 - SP Unlock & UserCode reset & IMEI changing 50 euro each | aj1rtd | Main Sales Section | 0 | 10-12-2002 16:01 |
Samsung Q100-Q105-Q200 - SP Unlock & UserCode reset & IMEI changing 75 euro each | aj1rtd | Main Sales Section | 0 | 10-01-2002 13:14 |
