10-18-2010, 19:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Problems unlocking a Huawei G3501 Any suggestions? Thanks Code: COM3 [VCP1] selected module v3.62 Device: Huawei-G3501 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup enabled ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:907C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00_06.BIN project-id: G3501CA_P63_M21_00_06, 00000000 code offset: 00000000 ffs offset/size [01]: 00A50000/00550000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A50000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G3501_GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00_06__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Huawei-G3501_GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00_06__ffs_20101018-143035.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... .................................. lock area found .................................. lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ....................... required data found flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: area 1 (pass 1) ......................................... area 1 patch applied Ok Special operation Done ====> Write ... flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: lock-area-1 flash: EC240200000000:2AEA0000000000 flash: EC240200000000:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 40 sec Remove/Install battery now ! |
10-20-2010, 18:40 | #2 (permalink) |
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | I've tried to make a full flash with the firmware that is in the support agreed with the eeprom of it and what I have achieved is that the cell turns to giving the logo MOVILNET and letters Any suggestions ????? Here the log of the procedure Code: COM3 [VCP1] selected module v3.62 Device: Huawei-G3501 Checking data, wait... advanced flash detection enabled Action: write flash "format ffs" active write: Firmware Huawei-G3501_GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00_06_2010-04-14_En_Es_Movilnet_Venezuela.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Huawei-G3501_ffs_06.B0E.bin ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:907C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: GOLD_S06_PCB01_GPRS_MT6223P_S00.G3501CA_P63_M21_00_06.BIN project-id: G3501CA_P63_M21_00_06, 00000000 code offset: 00000000 ffs offset/size [01]: 00A50000/00550000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A50000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: EC240200000000:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC240200000000:2AEA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2AEA0000000000 Finalization Done Finished, time used: 11 min 50 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-29-2010, 14:10 | #5 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Venezuela Age: 37
Member: 1165060 Status: Offline Sonork: 100.1615792 Thanks Meter: 75 | can you give us a tentative date? Quote:
We need extremely unlock Huawei G3501 and G5760 and others that have this same problem... | |
11-16-2010, 01:46 | #7 (permalink) |
Member: 1165060 Status: Offline Sonork: 100.1615792 Thanks Meter: 75 | Sorry for the insistence... Again... Sorry for the insistence... But if isn't too much to ask, can you give us a tentative date? No matter if isn't very accurate ... But it's something... We need extremely unlock Huawei G3501 and G5760 and others that have this same problem... |
06-21-2011, 08:22 | #10 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Click The link http://forum.gsmhosting.com/vbb/f296...-help-1292549/ |
06-22-2011, 03:42 | #11 (permalink) | |
Thread closed. I am unable to post the same answers in different threads again and again. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
