Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 398011 Status: Offline Thanks: 447
| problen unlock alcatel ot-103 an ot-203 domonican republic method is that you use to unlock the alcatel OT-103, OT-203, dominican republic here please help infinity team that released only via flash and only work with an operator either orange or alive flash Dominican for no clear released |
| The Following User Says Thank You to betina For This Useful Post: |
| | #2 (permalink) |
| method is that you use to unlock the alcatel OT-103, OT-203, dominican republic here please help infinity team that released only via flash and only work with an operator either orange or alive flash Dominican for no clear released when you give free dirct stay off / on the cell |
| | #5 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: infinity-box
Member: 1043909 Status: Offline Thanks: 8,922
| Quote:
As I know there is no any problems with these phones connection. There is a problem with unlock for several firmware versions, but we are working in this direction and problem will be solved soon. | |
| The Following User Says Thank You to YellowBoss For This Useful Post: |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 416710 Status: Offline Thanks: 35
| Yes sir, there are a new version or new hardware that not boot with infinity. You know I dont tell any lie, I test in many many phones and infinity or any other box dont detect. |
| | #7 (permalink) | |
| Quote:
I never heard about boot problems with 103/203 (but with other models this kind of problems may take place for new cpu type). | |
| | #8 (permalink) | |
| Quote:
Offtopic : DO you convert 708a firm and GPRS779 files, I need fix phones I have. | |
| | #9 (permalink) | |
| Quote:
New Alcatel files will be in support area in 1-2 days. Sorry for delay, it was a lot of files received last days. | |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 410795 Status: Offline Thanks: 33
| amigo solo tienes que darle a unlock y si se keda reiniciandose lees el imei que tiene detras el ekipo y se lo escribes con la infinity con eso ya keda nitido, espero haber ayudado! |
| The Following User Says Thank You to verneomar For This Useful Post: |
| | #12 (permalink) |
| @Celhack What was exact name (from phone back label) for your U82 model ? As I can see you can flash your phone with S215 firmware and phone should be repaired. I am not sure that it will be possible to make good firmware from your U82 backup. Flash your phone with S215A firmware from support area, let's see results. gprs779: need some more time to check it |
| | #13 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2009 Location: ZZ-KEY TEAM
Member: 1001831 Status: Offline Sonork: 100.1594557 Thanks: 207
| Full Unlock 103 COM3 [VCP0] selected module v3.34 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4F5D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 17E provider: 103A-2ATLPE3 customization: CM17NK41 customization: XM17NK41 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM17NK41 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B45C ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01187800510251 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201004 23-132111.B0X.bin Finished, time used: 1 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following User Says Thank You to MiChAGSM For This Useful Post: |
| | #14 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:06 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
