02-20-2014, 14:29 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: @ Ajmer
Member: 603777 Status: Offline Thanks Meter: 356 | Procedure to unlock lava- l661 via cdma-tool 1.First select L661 2.Select modem port and click diag enable. 3.Click read info to check if diag enable is ok. 4.Select diagnostic port and then click write efs. 5.Just write EFS only from below file 6.Your handset is unlock. here is link of flash file no need flash, then input unlock code. no need to buy any other tool!! here is link of flash file Download nor.rar from Sendspace.com - send big files the easy way all version will be unlocked via this method no need of downgread and other method Last edited by Infinity-CDMA; 02-21-2014 at 16:07. Reason: some information added. |
The Following 2 Users Say Thank You to krish491 For This Useful Post: |
02-21-2014, 01:43 | #2 (permalink) | |
No Life Poster Join Date: Jan 2007
Member: 441202 Status: Offline Thanks Meter: 120 | File is ok unlock write full flash then unlock Quote:
but when i was flash with full write flash option set unlock done and work perfectly without any code your file is unlock ok thanks to infinity team for l661 flasher work perfect on win 7 also all above for only unlock test result info for all users | |
The Following 3 Users Say Thank You to gb2qaz For This Useful Post: |
02-21-2014, 03:23 | #3 (permalink) |
Member: 441202 Status: Offline Thanks Meter: 120 | FLASHCHIP : SPANSION S71VS128RB0d=======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- Flashing : 16777216/16777216 done... Finished, time used: 7 min 56 sec |
02-21-2014, 16:04 | #4 (permalink) | |
Product Supporter Join Date: Jun 2010
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Please post us read info log. Quote:
Thanks for test report Please post us logs of read info to check is it supported or not or protection not is efs may be in firmware so after flash you changed whole firmware and phone got unlocked . Phone which i have in hand have this info : --------------------------------------------------------- HARDWARE : SBNAAHZ3 COMPILE : Jul 25 2013 (10:42:15) REALEASE : Apr 29 2011 (05:00:00) SW Version : Q1110 SBNAAHZ 3390 fh --------------------------------------------------------- Phonce code : 0000 Finished, time used: 1 sec and it work perfect just with efs flashing. Regard's Infinity-CDMA | |
02-22-2014, 15:20 | #5 (permalink) |
Insane Poster Join Date: Sep 2008 Location: Rajsthan {Merta Raod} Age: 45
Member: 873465 Status: Offline Sonork: [email protected] Thanks Meter: 7 | Thanks to infinity team for l661 flasher work perfect Write Full Flash set is Unlock Done |
The Following User Says Thank You to Ram M.T.D For This Useful Post: |
02-23-2014, 08:01 | #7 (permalink) |
No Life Poster Join Date: Jul 2009
Member: 1069446 Status: Offline Thanks Meter: 48 | FLASHCHIP : SPANSION S71VS128RB0d=======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- Flashing : 16777216/16777216 done... Finished, time used: 8 min 38 sec THNXXXXXXXX infinity team and who tested this solution |
The Following User Says Thank You to asiftak For This Useful Post: |
02-26-2014, 21:07 | #10 (permalink) | |
Member: 441202 Status: Offline Thanks Meter: 120 | Quote:
--------------------------------------------------------- HARDWARE : SBNAAHZ3 COMPILE : Oct 12 2013 (11:09:48) REALEASE : Apr 29 2011 (05:00:00) SW Version : Q1110 SBNAAHZ 3390 fh --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec | |
02-27-2014, 20:56 | #11 (permalink) | |
Member: 603777 Status: Offline Thanks Meter: 356 | Quote:
Need to full Flash!!!! it will be unlock via this method, i can say world first and only in the world | |
05-21-2014, 13:35 | #14 (permalink) |
Banned Join Date: Aug 2011 Location: India
Member: 1642979 Status: Offline Sonork: 100.1613407 Thanks Meter: 183 | COM80 [QCUSB_COM80_1] selected module v2.04 Device: Lava-L661 operation: Write EFS Phone should be Switched ON ! connecting... initializing... reconnecting... Wait reconnecting port... detecting port port ok.. sending bootloader... Wait reconnecting port... detecting port port ok.. did not respon... Finished, time used: 2 min 22 sec |
05-21-2014, 14:59 | #15 (permalink) |
Member: 1642979 Status: Offline Sonork: 100.1613407 Thanks Meter: 183 | --------------------------------------------------------- HARDWARE : SBNAAHZ3 COMPILE : Jul 25 2013 (10:42:15) REALEASE : Apr 29 2011 (05:00:00) SW Version : Q1110 SBNAAHZ 3390 fh --------------------------------------------------------- Phonce code : 0000 Finished, time used: 4 sec |
