procedure to unlok KP 170 with infinity success 100/100 procedure to unlok lg KP170 step by step 1- cable needed: * cable KE500 if you haven't cable use pin finder cable L18b RX=16 and TX=17 like picture http://www.freeimagehosting.net/uplo...ce51fdddac.jpg 2- run shell software select KP215 model 3- run format ffs like picture: http://www.freeimagehosting.net/uplo...040fe0d211.jpg phone is unloked successufly safe this is my expérience with kp170 |
please read full flash from kp170 and send to support |
after that imei goes to all zero and always saying sim card registration failed |
kp170 unlock success infinity teem, ihad unlock kp170 with infinity. i slect kp215 model and format it. now my set is unlock but phone imei gone to 0000000000000. loner is given below COM3 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 354789654125426 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354789654125426_LG-KP215_20091109-062850.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 354789654125426 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 64 sec Remove/Install battery now ! |
Hi after unlock i can't get any signal. Can you please help me? The imei is all zeros, can't infinity repair the imei? Am awaiting your speedy response. Venom |
I got it!!!!! I even have restore the original imei with infinity. Thanks infinity your tool IS THE BEST!!!!!!!!!!!!!!! Venom Fr Jamaica |
