03-29-2008, 02:57 | #1 (permalink) |
Junior Member Join Date: Mar 2005 Age: 43
Member: 125603 Status: Offline Thanks Meter: 0 | proplem with pin finder it can detect n73 chines pin out i try alot the volt is correct 4.96v he is power up when iwill power up in pin finder when i set pin ut manual it will not work in chinees marical wer is problem in pin finder can you help me |
03-29-2008, 11:38 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 19: Automatic pinout detection: Troubleshooting I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction. |
03-29-2008, 14:31 | #3 (permalink) |
Member: 125603 Status: Offline Thanks Meter: 0 | i will tray the truble shoting maual alredy i will cut dyte in infinty box the power in first is 4.26v now power is in first computer 4.96v in secand computer 5.06v the same proplem can't detact pin out for n73 chineas |
03-29-2008, 22:44 | #5 (permalink) |
Member: 125603 Status: Offline Thanks Meter: 0 | the phone name n73 chineas cable L14f dku2 when i will detect it in pin finder program it will not detact it when i set pin (tx&rx) manule not work when i replace the power cable in pin finder with battriey the chineas marical will respons but error massege will apeare bad ffs bad eeprom the same problem will apeare with me in n95 dual slider but in end the pin finder will detect it after 3 hours of test |
03-30-2008, 00:17 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Sorry, but I don't understand the problem well. What is the problem exactly ? Pin detection problem or bad eeprom ? To avoid 3 hours of tests be sure that cable connected well to phone, that phone connector is clean and not damaged and be sure that phone has Rx and Tx on bottom connector but not test-points on PCB. |
03-30-2008, 15:12 | #7 (permalink) |
Member: 125603 Status: Offline Thanks Meter: 0 | i say the mobile name n73 cable L14f when i will detect it in pin finder program it will not detact it (ican detact rx@tx) for these mobile and (cect c1000) And (nokia n96i) the same problem i can detect (rx&tx) on other model mobile all thing is ready |
03-30-2008, 18:14 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | i say read please: http://www./showpo...52&postcount=6 |
04-01-2008, 11:31 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Location: egypt Age: 51
Member: 52847 Status: Offline Thanks Meter: 73 | hi hi i have problem in my pinfinder for some models like n99i tx rx detected good & fast problem is phone power on & turn of again ,.. my rj45#2 cables come s with 10 pins i need pinout for 8 pins correctly,,, help plz ,,thanks |
04-01-2008, 12:22 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, see detailed pinout description here: http://www.infinity-box.biz/download..._PinFinder.pdf |
Cect V329 - cannot detect pin with Pin-finder | loukandr | Infinity-Box | 17 | 03-18-2009 19:58 |
Problem with Pin Finder Adapter | BouRRi_GSM | Infinity-Box | 14 | 07-18-2008 23:24 |
I Cant Connect Nokia N73 With Pin Finder | malpinssa | Infinity-Box | 3 | 05-08-2008 20:41 |
Help With Nokla 6300 With Pin Finder | palash_c6 | Infinity-Box | 2 | 05-06-2008 17:23 |
cect q380 can't find pin outs with pin finder | kiran | Infinity-Box | 4 | 04-09-2008 09:12 |
