07-19-2013, 08:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ports***** UK Age: 44
Member: 126675 Status: Offline Thanks Meter: 13 | PxPhone i9220 MT625a - problem with reading full flash I have PxPhone i9220 with MT625A CPU, and I'd like to translate, but I can not read backup. How can I read backup? Code: [Infinity Box] MModule v4.45 smart-card: connected (Axalto e-gate 0) S/N: 0694:0120:00 Wait... trying to select model: /AUTODETECT model selected via command line: _Autodetect MT6205-6239 NOR Device: _Autodetect MT6205-6239 NOR Initialization done Device: _Autodetect MT6250-6253 etc. ==== [2013-07-18 16:42:59] ==== COM98 [VCP1] selected module v4.45 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 0000:0000:0000 status: 00 bbchip bl ver: 00 NOR chip is not detected NAND chip is not detected Repeat operation, Press and HOLD Power button more long time ! internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: 00 error: can not boot device: 07E6:S_BROM_FAIL_TO_GET_BBCHIP_HW_VER error: last error: 07E6:S_BROM_FAIL_TO_GET_BBCHIP_HW_VER Disconnect... done Finished, time used: 1 min 5 sec Remove/Install battery now ! Device: _Autodetect MT6228-6276 NAND In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [2013-07-18 16:44:31] ==== COM98 [VCP1] selected module v4.45 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 0000:0000:0000 status: 00 bbchip bl ver: 00 NOR chip is not detected NAND chip is not detected Repeat operation, Press and HOLD Power button more long time ! internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: 00 error: can not boot device: 07E6:S_BROM_FAIL_TO_GET_BBCHIP_HW_VER error: last error: 07E6:S_BROM_FAIL_TO_GET_BBCHIP_HW_VER Disconnect... done Finished, time used: 38 sec Remove/Install battery now ! Device: _Autodetect MT6205-6239 NOR ==== [2013-07-18 16:45:21] ==== COM98 [VCP1] selected module v4.45 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 22 sec Remove/Install battery now ! http://gsmpro.com.pl/data/PxPhone_3.jpg http://gsmpro.com.pl/data/PxPhone_2.jpg http://gsmpro.com.pl/data/PxPhone_1.jpg |
