10-10-2014, 14:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | Q A2 classic hangs at logo Card found: S/N 000000 Chinese Miracle II [MTK module] v 1.01 Operation : Check / Read Info [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Processing DA stage DA Stat : v3.2 on BBID : 0x84 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0073 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 [NAND] : FLASH_LEN : 0x20000000 NAND not supported yet INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Boot Error! Operation Failed Elapsed: 00:00:38 Reconnect Power/Cable! |
10-10-2014, 15:26 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. There is test version with nand support, but 6575 not work propper. Leave phone until tomorrows evening, I'll get phone at morning and add 6575 support. |
