01-25-2016, 13:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: pakistan(Timergara) Age: 37
Member: 1224733 Status: Offline Thanks Meter: 158 | Q m95 flash succesfully,but phone still hang on logo Chinese Miracle II [SPD module] v 1.07 Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Operation : Flash [ v1.07 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:05:17 Reconnect Power/Cable! |
01-25-2016, 23:23 | #3 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Ghana
Member: 1809548 Status: Offline Sonork: mysty619/100.167036 Thanks Meter: 120 | Try to make full factory reset in recovery or use cm2 to make a full factory reset after flash.. |
The Following User Says Thank You to mysty619 For This Useful Post: |
01-26-2016, 13:25 | #4 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Quote:
http://www.4shared.com/rar/He3v1HNec...ments#62685147 | |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
07-14-2016, 11:20 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: bahawalpur pakistan
Member: 821900 Status: Offline Thanks Meter: 26 | q m95 hang on logo i flashed with cm2 file SP7731GEA_scx35_sp7731gea_4.4.3_KOT49H_14B_test-keys flash done but hang on logo any one solved logs are here Chinese Miracle II [SPD module] v 1.18 Infinity SC Firmware Detected FW Size : 1239 MiB Load Ok! Operation : Flash [ v1.18 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 40 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Flash [ v1.18 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Flash [ v1.18 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:03:32 Reconnect Power/Cable! |
07-14-2016, 13:27 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Make sure the file you are using is from same HW Rev and from working phone. Also make Flash IC Test. Br. Infinity Box Support Team. | |
10-24-2016, 12:56 | #10 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | i have also tw2 m95 and 1 t480 already flashed many firmware flashed format every thing is done but hang logo i think its hardware problem |
