Old 11-06-2015, 11:29   #1 (permalink)
Member: 2394595
Thanks Meter: 21
Arrow q mobile a110 not format or read scatter
q mbile a110 not format or read scatter also change aal setting of nand
 , v0129
Chinese Miracle II  [MTK module] v 1.35
Operation : Format FileSystem [ v1.35 ]
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND :
Error : DA init Failed! Error code : 0x4
LErr : 0000
Boot Error!
Operation Failed
Elapsed: 00:00:05
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND :
LErr : 0000
Boot Error!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND_ID : 00C800F4000000000000000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x009F , [Gigadevice] GD5F4GQ4UAYIG
[NAND] : FLASH_DIE : 00C8 00F4 0000 0000 0000 0001 0BC7
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:13
volcano done format plz explain y not read cm2
Old 11-06-2015, 11:38   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,654
Have no idea at all. If will be more reports about problem - will check.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-06-2015, 13:06   #3 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,817
 , v0129
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND :
LErr : 0000
Boot Error!
Operation Failed
Elapsed: 00:00:05
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND :
LErr : 0000
Boot Error!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:13
yes cm2 not format and other operation not support qmobile A110
Old 11-06-2015, 13:26   #4 (permalink)
JayDi's Avatar
Member: 462970
What if set correct NAND init mode?
Old 11-06-2015, 14:07   #5 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,977
Hello,
i think (not sure) this model supported with CM2 with correct Init mode setting
right now, not at shop,
Tomorrow, i will check and post logs
Old 11-06-2015, 16:42   #6 (permalink)
JayDi's Avatar
Member: 462970
I made in v1.36 Universal NAND reader. Hope, it will cover rest models. It not requre "INIT" settings at all.
Version, probably, already on support, or will be in near time.
Page generated in 0.27072 seconds with 7 queries
