05-20-2016, 14:29 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: lahore..Pakistan Age: 34
Member: 2486822 Status: Offline Sonork: 100.1659206 Thanks Meter: 77 | Q mobile a300 dead after flash Chinese Miracle II [MTK module] v 1.47 Load File File_Info : s7810bp FileVersion : MT6572 Load File Ok Operation : Flash [ v1.47 ] ======= Flash Files set for flashing : [ MCU ] : MTK6572_1403021306.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048600A3F4C0B071 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3F4C0B071 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : CFDD699FB2E0A5639C4C02A04888B9AA INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : QMobile ProdName : A300 ProdModel : QMobile A300 Device : QMobile A300 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P65 ISPFF ID : 6572 , TARGET ID : 6572 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MTK6572_1403021306.bin Init Ok , Sending blocks ... Write failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:45 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.47 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048600A3F4C0B071 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3F4C0B071 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : CFDD699FB2E0A5639C4C02A04888B9AA INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3627 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E3E00000 Flash Pre-Erase Done, time used : 00:00:22 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s7810bp.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Operation Failed Elapsed: 00:01:22 Reconnect Power/Cable! |
05-20-2016, 14:44 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Read scatter from working phone with same preloader, then flash phone again you will succeed. |
The Following User Says Thank You to Kirumira For This Useful Post: |
05-20-2016, 16:16 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | No, it not help. Need for start read SW logs. Exactly last lines. If given advise not help - time to change FlashIC. It became dead. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
05-20-2016, 16:20 | #4 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Qmobile A300 have 2 different firmware , you have flashed with wrong one. still you have a chance to recover it by flashing correct firmware you can have firmware from the thread started by someone on CM2 section thread name is All Qmobile flash file read by CM2 |
The Following User Says Thank You to khanzada606 For This Useful Post: |
05-21-2016, 07:18 | #5 (permalink) | |
Member: 2486822 Status: Offline Sonork: 100.1659206 Thanks Meter: 77 | Quote:
first i hardreset it but problem was not solve. then i (reset privacy lock) with cm2 but not succes then i flash with bin file and scatter file after flashing mobile was dead | |
05-21-2016, 08:24 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Encryption Unsuccessful is due to either software or hardware. If you are finished with software then it's time to repair phone via hardware. Br. Infinity Box Support Team. |
05-21-2016, 08:27 | #8 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | H/W Flash ic dead no solution |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
