Old 06-18-2016, 06:57   #1 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
Q mobile A910 Repartition Failed! Something wrong with HW or BL? Try make "Flash Eras
======= Flash
Wait for phone...
Phone found! [ 75 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A3DCA63175
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3DCA63175
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xB7339DBD714F97C337C6A825B4EBFA2C
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s8513a , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3760 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:07
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s8513a.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:51
Reconnect Power/Cable!
Old 06-18-2016, 10:20   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Make FlashIC test in Extra tab.
Old 06-18-2016, 10:20   #3 (permalink)
JayDi's Avatar
Member: 462970
Hello.
Old 12-17-2016, 14:32   #4 (permalink)
Member: 2562243
Thanks Meter: 7
what benefit of make flash ic test in extra tab
Old 12-17-2016, 14:39   #5 (permalink)
Member: 1840260
Thanks Meter: 166
untick repartition from cm2 bro
Old 05-22-2017, 14:34   #6 (permalink)
Member: 2711346
dude please what is the use of the Flashic test
Old 05-23-2017, 05:41   #7 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Le papa11 Bro..
Brother Making Flash IC test will help you to flash your phone. If test says "Read Only" state it means nothing can be changed through flashing process.
If it says "Bad or corrupted Flash IC" means returns back to its owner in-spite being hang at Logo.
If test is "passed" {Read Write passed} means you can flash the mobile by changing or same exact flash file.
Hope this is enough information for you.
B/R
Sheraz..
Old 05-23-2017, 06:05   #8 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
Originally Posted by JayDi View Post
Hello.
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BM41X
[eMMC] : FLASH_CID : 150100525831344D420717F0C2AC93FB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD72A578BE10E95AEE78E36E594CE6DD6
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BM41X , 0x747C00000 , 29820 MiB
[eMMC] : CID : 150100525831344D420717F0C2AC93FB
[eMMC] : MODE : SQ-WR
[FAILED] : Probably, something wrong with eMMC! Check cable and battery!
Operation Failed
Elapsed: 00:00:16
Old 05-23-2017, 06:11   #9 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
B/R
Sheraz..
1 mobile phone not show dail namber
2 format with CM2 Hang on logo
3 Mobile show this error writte flashing
4 At this time mobile phone Fully dead
Sorry for bed English
Old 05-23-2017, 06:17   #10 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 634
Sorry this is my old post
please delete my post
my new post here
http://forum.gsmhosting.com/vbb/f296...ailed-2227157/
Page generated in 0.22345 seconds with 9 queries
