02-17-2010, 00:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Q-mobile i need flash file for this model Code: COM3 [VCP0] selected module v3.03 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8A5C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:2BCA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 2B0000CA18D09FC518D09FC518D09FC518D09FC518D09FC5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:2BCA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ........................................................ can't detect ffs/eeprom record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 26 sec Remove/Install battery now ! |
02-17-2010, 08:56 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, it looks like phone flash chip content is damaged, even information about firmware version name is absent. You must find suitable firmware and flash phone first. |
02-22-2010, 17:49 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! search similar picture in the internet and find out what is your phone model name. or try one by one all available on support flash files for Q-mobile |
02-22-2010, 21:17 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | QMobile-E400 firmware can be downloaded from support area: \flashfiles\QMobile\E400 Also QMobile-E200 flash files will be uploaded in support area in short time. Q26 or Q180 is also available on support Last edited by InfinityHelp; 02-22-2010 at 21:47. |
01-18-2016, 16:27 | #11 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1269964 Status: Offline Thanks Meter: 1 | qtab q120 firmware infinitybox cm2mtk rede qtab q120 firmware infinitybox cm2mtk rede Last edited by nasir faraz; 01-18-2016 at 16:27. Reason: https://mega.nz/#!8UYV2IpC!DSefTk8UAsp6DAO9gkjnYS6hgSCR1nYxKNobogM8ojk |
need flash file for this mobile | ronygsm123 | Chinese Models & Cloned Phones | 0 | 12-13-2009 13:36 |
plz i need this flash file for this model | ahmed nokia | SpiderMan | 1 | 09-18-2009 20:37 |
need flash file for e90 model | mahesh_patel361 | SpiderMan | 6 | 09-05-2008 13:28 |
need flash file for e90 model | mahesh_patel361 | ET-BoX | 0 | 09-03-2008 10:58 |
GPRS779 any flash file for this model | manuelalejandro | Infinity-Box | 1 | 04-19-2008 09:48 |
