10-12-2015, 09:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile I5 Kitkat Monkey Tes,Time Service and much others Solve By InfinityBoxCM2MTK Q Mobile I5 Kitkat MT-6582 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Code: Operation : Remove Viruses [SmartAV] [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A29E6832F3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A29E6832F3 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 37 Removing infected files and scripts ... SmartAV Report : Removed 37 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:07 Reconnect Power/Cable! Before After ˙·٠•●♥ I'm Not "HANDSOME" ˙But I Can Give My "HAND" To "SOME" One Who Needs Help. Beauty Is In Heart,Not On Face...! ·٠•●♥ Last edited by ::SYED MOBILE::; 10-12-2015 at 09:10. Reason: Add Some Text |
The Following 18 Users Say Thank You to ::SYED MOBILE:: For This Useful Post: |
10-12-2015, 10:15 | #3 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | Done. LAVA inis X1+ Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513758534142016494FC4332F7 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 150100513758534142016494FC4332F7 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 160 Removing infected files and scripts ... SmartAV Report : Removed 99 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:03:11 Reconnect Power/Cable! |
10-14-2015, 12:13 | #6 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile A600 MT-6583 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
The Following User Says Thank You to ::SYED MOBILE:: For This Useful Post: |
10-16-2015, 14:43 | #7 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile A63 MT-6572 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-17-2015, 11:21 | #8 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Chines Phone innjoo one MT-6572 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
The Following 2 Users Say Thank You to ::SYED MOBILE:: For This Useful Post: |
10-18-2015, 11:49 | #9 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile A910 MT-6582 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-21-2015, 06:29 | #10 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile A500 MT-6583 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-21-2015, 06:33 | #11 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | China Tab Ctroniq MT-6572 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-21-2015, 06:40 | #12 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Huawei Y600-U20 MT-6572 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-21-2015, 12:08 | #13 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Q Mobile A8i MT-6572 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-22-2015, 13:56 | #14 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Samsung Clone Grand G7102 MT-6582 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
10-25-2015, 06:15 | #15 (permalink) | |||
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Turbo X Tab MT-6582 Monkey Tes,Time Service and Much Others Solve By InfinityBox CM2MTK Quote:
The Following 3 Users Say Thank You to ::SYED MOBILE:: For This Useful Post: |
