Old 03-03-2016, 12:29   #1 (permalink)
Member: 2520383
Q MObile invalid Imei
Operation : Check / Read Info [ v1.41 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 03-03-2016, 12:47   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,977
Hello,
Post more info , model , info logs ....
Install driver from support site only
read/check software Instructions carefully .
Old 03-03-2016, 13:39   #3 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
QMobile Nore A6
show invalid imei
i m trying to repair it but show this eror
Old 03-03-2016, 14:16   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,978
Hello,
Select correct cpu, check cable, driver, battery, connection,etc.due to some reason phone cannot boot properly.
Also recommended to use CM:Permanent Mode.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-03-2016, 15:24   #5 (permalink)
Member: 2520383
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594815A13A7960CFFF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 086FAB87ABFFAE0ADF50B5545D554198
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok
IMEI [00] : 354526050103973
IMEI [01] : 354526055103978
Set IMEI [00] : 354526050290044
Set IMEI [01] : 354526055290049
Prepare finished. Security check required!
Page generated in 0.23013 seconds with 7 queries
