04-06-2016, 18:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Q mobile lt700 mtk 6735 3 gb ram read flash done Code: Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5200011541423133FFAF064289871DF2 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BAB13 [eMMC] : FLASH_CID : 15010052333142414206AFFFF21D1389 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : A03EA34442775528702EC7028957B2DB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : LT700 ProdModel : LT700 Device : GBL7325QM AndroidVer: 5.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325QB_0306_T5848 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5200011541423133FFAF064289871DF2 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BAB13 [eMMC] : FLASH_CID : 15010052333142414206AFFFF21D1389 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : A03EA34442775528702EC7028957B2DB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : QMobile ProdName : LT700 ProdModel : LT700 Device : GBL7325QM AndroidVer: 5.0 MTKxCPU : MT6735 MTKxPRJ : GBL7325QB_0306_T5848 [Read Ok] : preloader_gionee6735_65c_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6735 / V1.1.2 / gionee6735_65c_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2687 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6735__QMobile__LT700__GBL7325QM__5.0__GBL7325QB_0306_T5848\ All done! Code: Scatter Load Ok , BaseBand : MT6735 , Project : gionee6735_65c_l , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : GBL7325QM Device CPU : MT6735 Device IntName : LT700 Device Version : 5.0 Device Compile : 1/12/2016 5:02:00 AM Device Project : GBL7325QB_0306_T5848 Device ExtInfo : LT700 Ready to Flash! |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
