12-30-2015, 06:42 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Card found: S/N : 74A4D2CC , v0129 Chinese Miracle II [SPD module] v 1.09 Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 189 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 189 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : M88 Model Brand : QMobile Model Device: M88 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA Project Ver : QMobileM88_MP_31_07 Model Ext : QMobile M88 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img Firmware Size : 1019 MiB Saved to : C:\Documents and Settings\karchimob\Desktop\SP7731GEA_M88_4.4.2_QMo bileM88_MP_31_07\ Done! Elapsed: 00:19:53 Reconnect Power/Cable! Read 100 done please give flashing method |
12-30-2015, 07:00 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Select SC77xx ( any ) Go to Flashing Tab Press "PAC" button Select in Filter "*.pac.sc" file type, select SC77xx_FLASH_CONF.pac.sc , which is inside C:\Documents and Settings\karchimob\Desktop\SP7731GEA_M88_4.4.2_QMo bileM88_MP_31_07\ folder Press "Flash" Next time - spend some time for MANUALS, which explain ALL need things. |
12-30-2015, 07:27 | #6 (permalink) | |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
Thanks infinity team Card found: S/N : 74A4D2CC , v0129 Chinese Miracle II [SPD module] v 1.09 Infinity SC Firmware Detected FW Size : 1019 MiB Load Ok! Operation : Flash [ v1.09 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 189 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... | |
12-30-2015, 07:39 | #7 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | 1 audio sound not working 2 read firmware(pac) from working phone 3 write in faulty phone 100% done 4 100% audio sound recover with cm2 |
