07-21-2016, 09:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2016 Location: Pakistan Age: 27
Member: 2511027 Status: Offline Sonork: 100.1662953 Thanks Meter: 1,113 | Q Mobile M95 v2 Blue Display Successfully Recover Done By Cm2 Q Mobile M95 v2 Blue Display Successfully Recover Done ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_720x1280.bin Write Data ... Write Data Ok! Write CodeData : fblogo_720x1280.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:03:49 Reconnect Power/Cable! Regards Kashif_Iqbal |
The Following 7 Users Say Thank You to KAS HIF For This Useful Post: |
07-21-2016, 18:41 | #3 (permalink) |
Freak Poster Join Date: Oct 2007 Location: GOA
Member: 600436 Status: Offline Thanks Meter: 219 | is main display recover karne ki baat hai is main display recover karne ki baat hai tested file dal diya to gya koi bhi tool se hojata |
The Following User Says Thank You to prakashmborana For This Useful Post: |
08-03-2017, 11:02 | #7 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Peshawar Pakistan
Member: 2613197 Status: Offline Sonork: 100.1673396 Thanks Meter: 29 | Qmobile m95 display blue brothers please look beside undercover that s u r phone are which model like m95 v2 v1 0r simple m95 if its m95 v2 then download same file and then flash it |
