02-12-2016, 12:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Why ? with rest setting samsung clone Lost logo Always samsung logo lost ? please give me solution customer angry on mediatek android logo Code: Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E3957524D4201BEA06620C0E3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D4201BEA06620C0E3 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-12-2016, 12:51 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Thats normal,Logo for clone Samsung phones is done by Codes NOT by File. Search for codes on net you will get them or start with this *#8800# |
02-12-2016, 13:02 | #4 (permalink) | |
Member: 1726229 Status: Offline Thanks Meter: 223 | Quote:
1: *#*#1478963#*#* 2: *#*#0066#*#* 3: *#*#11111#*#* 4: *#7501# 5 : *#91# #*#94#*# *#123321#* | |
02-12-2016, 13:59 | #8 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Hello Guys! I resolved the problem! When you reset the phone to factory, the bootanimation.zip change the name to bootanimation_2.zip, and it not recognize from the boot_logo The solution is enter in Root Mode, with a FX Root Explorer, for example, and RENAME the archive in SYSTEM(ROOT)/MEDIA. (P.S. You must mount the Unit as READ/WRITE) Change the name of bootanimation_2.zip to bootanimation.zip and Reset the phone. I think the problem is resolved, 99%!!! |
The Following User Says Thank You to sneha For This Useful Post: |
02-12-2016, 14:05 | #9 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | 1 more Best way of doing it is manually if you are rooted. Get 'Root Explorer' and go to /systen/media Then rename "bootanimation1.zip" to "bootanimation.zip" and "shutanimation1.zip" to "shutanimation.zip" Then go into the "images" folder there and remove "boot_logo" and rename "boot_logo1" to "boot_logo" and last part rename "bootaudio1.mp3" to "bootaudio.mp3" |
03-06-2016, 12:51 | #13 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
probably you will get in 1% succeed and 99% failed. | |
03-06-2016, 15:15 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Why not make own logo and use it? More faster and easy. Even not need make, enough copy from similar screen size model. No root, spending time for unknown result and etc. |
