01-02-2016, 14:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Q mobile X2 Pattern lock ?? today i recevd x2 ([MediaTek] MT6571) i try read pattern but cm2 log say Pattern / DP Lock not set! then i hard rest via keys (loss Data) Code: Card found : S/N : ADACA0AA , v0129 Chinese Miracle II [MTK module] v 1.40 Operation : Read Pattern/DP Lock [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... Pattern / DP Lock not set! Done! Elapsed: 00:01:39 Reconnect Power/Cable! |
01-02-2016, 14:36 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Hope you have made firmware backup with pattern lock before format/hard reset. Just rar that folder and upload somewhere and post link. Team will try to support it in coming updates. Br. Infinity Box Support Team. |
01-02-2016, 15:10 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I spend much time to make different cases and situation to get best result. But there is infinite count of variations. If user get problem and not want see it in future - he must help us. At least - by report and dump. Just info for future. |
