Old 05-22-2017, 14:04   #1 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Q mobile Z14 Main PMT update failed!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41X
[eMMC] : FLASH_CID : 150100525831344D420717F0C2AC93FB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD72A578BE10E95AEE78E36E594CE6DD6
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Operation Failed
Elapsed: 00:00:29
Reconnect Power/Cable!
Old 05-23-2017, 04:01   #2 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Build new PMT ...
Update Primary ...
Old 05-23-2017, 04:26   #3 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Initial info read error! Erased or damaged FlashIC?!
Force eMMC test by user request
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BM41X , 0x747C00000 , 29820 MiB
[eMMC] : CID : 150100525831344D420717F0C2AC93FB
[eMMC] : MODE : SQ-WR
[FAILED] : Probably, something wrong with eMMC! Check cable and battery!
Operation Failed
Elapsed: 00:00:29
Page generated in 0.20352 seconds with 7 queries
