11-04-2015, 12:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india-gujrat-nadiad
Member: 384984 Status: Offline Thanks Meter: 456 | q1010i imei repair faild? imei is invalid i repair with both method but failed hear is log========================= Start ========================= 11/4/2015 / 4:18:15 PM ================================================== ======= Card found : S/N : 10B0DE99 , v0129 Chinese Miracle II [MTK module] v 1.34 Start at : [11/4/2015 / 4:21:02 PM] Operation : Repair Security [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... ate signaling test modecm2 method logCard found : S/N : 10B0DE99 , v0129 Chinese Miracle II [MTK module] v 1.34 Operation : Repair Security [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42013E27C21F4163 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42013E27C21F4163 [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 911363601869266 IMEI [01] : 911363601969264 Set IMEI [00] : 911363601869266 Set IMEI [01] : 911363601969264 Prepare finished. Security check required! Wait for phone... Phone found! [ 16 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:49 Reconnect Power/Cable! how can i recover my imei |
11-04-2015, 12:19 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | For start - check baseband state and repair it first. Then repair rest things. |
