Old 11-24-2017, 16:43   #1 (permalink)
Member: 2553465
Thanks Meter: 19
qi6 metal 1 not flash solution
Scatter Load Ok , BaseBand : MT6580 , Project : v3702 , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : i6_Metal_HD
Device CPU : MT6580
Device IntName : i6_Metal_HD
Device Version : 6.0
Device Compile : 3/17/2016 11:17:12 AM
Device Project : ALPS.W10.24.p0
Device ExtInfo : i6 Metal HD
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:28
Reconnect Power/Cable!
======= Flash
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505073125D4F2234D
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505073125D4F2234D
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x092DD186F827034E0C8AE8D440890888
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : v3702 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3007 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x00000001CAF60000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_v3702.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:12
Old 11-26-2017, 05:52   #2 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 427
Secure Phone
Flash With Avenger
Page generated in 0.12007 seconds with 8 queries
