-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Qlm cm2 program is not connected to the phone (http://forum.gsmhosting.com/vbb/f296/qlm-cm2-program-not-connected-phone-2159563/)
jhan n73 11-24-2016 13:09
Hi I want to use a normal phone Y530-U00 Flash Reed Bgyrmmtasfanh do anything not attached to the positive and negative volume keys up my computer and I connected the phone to update dongle according to Fashion is not Ltfamnv tips
jhan n73 11-25-2016 19:27
Help mi ..,.........,.....
Kirumira 11-26-2016 05:47
Uninstall all Qualcomm drivers on your pc,
Download drivers from support,then do your work
.:MobileLife:. 11-26-2016 06:03
Download QLM drivers from support unzip and install 3 exe files restar pc and post result.
jhan n73 11-26-2016 06:24
I also did the same thing.
mrnice2 11-26-2016 06:42
Mine is working fine now, after installing the 3 drivers from the installed location of the downloaded driver. Thanks. Even though, this is not my thread.
Tabu43 11-26-2016 08:56
use nokia emergency x2 drivers for qualcomm phones connected.
.:MobileLife:. 11-28-2016 06:44
Uninstall all Qualcomm drivers if needed use dc uninstall client restar pc and repeat install 3 exe file should be work.
rohit.sharma73 11-28-2016 18:06
Same problem qlm not boot usb driver i use win8.1 and win7 plzzz
i find nokia emergency driver this manual xpdriver show plzz win7 and win8 driver link here.............................
JayDi 11-28-2016 18:16
http://forum.gsmhosting.com/vbb/f296...video-2160627/
tesar.thea 08-25-2018 04:29
Reconnect Power/Cable!
Operation : Read PatternLock [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
BREAK : Device not found!
HINT : Check cable, connection and drivers!
urvasivadana1 08-25-2018 04:30
Wait for phone...
Drivers Check
Emergency Drivers install
Page generated in 0.25465 seconds with 5 queries
