03-29-2019, 01:18 | #1 (permalink) |
Registered User Join Date: Apr 2007
Member: 484250 Status: Offline Thanks Meter: 21 | QLM doesn't detect devices in DIAG unfortunately the QLM module doesn't detect devices in DIAG mode. Drivers are installed correctly because the device is working fine in QxDM (QPST) and other tools detect it without any problems. EDL detection is working fine but DIAG not. Do you know what should be wrong please? Why there is no manual COM port selection? |
03-29-2019, 01:36 | #2 (permalink) | |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | Quote:
right click on 9008 port driver now uninstall and restart pc and try again | |
03-29-2019, 06:25 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | As it was stated in a post before, to use qcom in hsusb9008 port, you need to install Emergencydrivers and it will be like Care emergency drivers in device manager, not com port |
03-29-2019, 08:01 | #9 (permalink) | |
Registered User Join Date: Apr 2015 Location: pleiku
Member: 2382850 Status: Offline Thanks Meter: 111 | Quote:
https://www.youtube.com/watch?v=jzYb...ture=********* test Last edited by davidstore; 03-29-2019 at 08:11. | |
03-29-2019, 08:10 | #10 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Download this http://dl1.infinity-box.com/00/pub.p...ivers_v1.01.7z Read carefully"Release txt" for instructions. | |
The Following User Says Thank You to Kirumira For This Useful Post: |
03-29-2019, 08:15 | #11 (permalink) | |
Member: 484250 Status: Offline Thanks Meter: 21 | I understand but it is for edl = 9008 qualcomm driver. My troubles are with diag mode. It is totally different mode. Edl - device turned off, used for frp, memory dump, flashing etc Diag mode - device ON, used for qcn backup, imei repair etc. Quote: | |
The Following User Says Thank You to MaClaud1 For This Useful Post: |
03-29-2019, 08:32 | #13 (permalink) |
Member: 484250 Status: Offline Thanks Meter: 21 | Alcatel 9007x but I enabled the diag port. Qpst communicates with it without problems but cm2 doesn't. Please chcek the picture in my first post - you can see that diag port is present but cm2 doesnt detect it.Sent from my Pixel 3 using Tapatalk |
04-01-2019, 23:49 | #15 (permalink) |
Member: 484250 Status: Offline Thanks Meter: 21 | Hi guys, still no success. My driver is installed correctly but CM2 doesn't detect the device. I tested it with several computers, several devices and the result is still same - I cannot backup QCN and repair IMEI. Can you explain me how to do that please? How CM2 does detect device in DIAG mode? please chek my situation: |
