01-26-2018, 13:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: india
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | qlm flasher error pls guide me Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 052A8644 ID_BLOCK_E : 00010001 ID_BLOCK_L : 8244F05D89A3473AEBE173276EF4B9F0 ID_BLOCK_L : 4847B234C2422314D2C45884BE820264 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Lenovo ProdName : A6020a40 ProdModel : Lenovo A6020a40 Device : A6020a40 AndroidVer: 5.1.1 Manufact. : LENOVO SysPatch : LMY47V DevComTime: 19/05/2016 09:47:50 QLMxCPU : MSM8916 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:32 Reconnect Power/Cable! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 052A8644 ID_BLOCK_E : 00010001 ID_BLOCK_L : 8244F05D89A3473AEBE173276EF4B9F0 ID_BLOCK_L : 4847B234C2422314D2C45884BE820264 Pickup loader from firmware package FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! this error was started after formating my computer . before fomating everything was perfect. I installed programmes and drivers in my knowledge.. pls help me to solve this issue,,,,, |
01-26-2018, 13:50 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Download Drivers from here http://dl1.infinity-box.com/download...ivers_v1.01.7z Get Good Firmware compatiable with your phone. |
01-26-2018, 14:23 | #4 (permalink) |
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | [QUOTE=JayDi;12928090]FW, which you had selected are NOT compatible with that device.[/QU i will download firmwares and ibform you thanks for your reply |
01-27-2018, 09:47 | #5 (permalink) |
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | first I read its own firmware and flashed no errors in flashing then downloaded three different firmware. also one from our support area. tried all,,, but same error, pls give me a suitable firmware link Card found : 87195A77 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Lenovo Device Manufact.: LENOVO Device Model : A6020a40 Device CPU : MSM8916 Device IntName : A6020a40 Device Version : 5.1.1 CU_SWVer : LENOVO Device Compile : 19/05/2016 09:47:50 Device ExtInfo : Lenovo A6020a40 Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 052A8644 ID_BLOCK_E : 00010001 ID_BLOCK_L : 8244F05D89A3473AEBE173276EF4B9F0 ID_BLOCK_L : 4847B234C2422314D2C45884BE820264 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 32 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : misc.img Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:04:43 Reconnect Power/Cable! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 052A8644 ID_BLOCK_E : 00010001 ID_BLOCK_L : 8244F05D89A3473AEBE173276EF4B9F0 ID_BLOCK_L : 4847B234C2422314D2C45884BE820264 Pickup loader from firmware package FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
01-27-2018, 10:32 | #7 (permalink) | |
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | Quote: its file name shows its other model A6020a46_USR_S105_1611242000_Q1021101.2_BMAIN_16G_ ROW_qpst and my phone model is A6020a40 is it suitable ??? | |
01-27-2018, 12:54 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Yes a little mistake in providing file. Anyways HERE it is. Post result. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-27-2018, 13:56 | #9 (permalink) | |
downloaded the above file still same error Card found : 87195A77 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 052A8644 ID_BLOCK_E : 00010001 ID_BLOCK_L : 8244F05D89A3473AEBE173276EF4B9F0 ID_BLOCK_L : 4847B234C2422314D2C45884BE820264 Pickup loader from firmware package FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! | |
01-29-2018, 07:01 | #10 (permalink) | |
problem not solved any way to solve the problem, any workaround with memory tool ?,, it initialise correctly with memory tool, if yes pls give me a detailed help... | |
01-30-2018, 07:54 | #14 (permalink) | |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Your Solution, Quote:
Your solution is in your logs provided...... ID_BLOCK_I : SnapDragon 415 [MSM8929] ....... . Mean ...see your CPU its MSM8929. and your are trying to flash it with different CPU like MSM8936 or other it will not take the firmware..... Download the firmware which have this processer.... this is not important that its Lenovo A6020a40 OR Lenovo A6020a46 . Because i was also in this situtation and i has resolve by this way..... Now do not remember which firmware it was 106 or other do not remember. But your problem is mismatch of processer. When has same processer file it will ok. Accutally this processer is very rare CPU. I think it will help you. Try 105-106-107. One will help you. Thanks Br, Raja | |
The Following User Says Thank You to rajamtkmaster For This Useful Post: |
