Old 05-14-2016, 13:02   #1 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Qmbile i9 check log
Operation : Flash Erase [ v1.47 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048602A3540631DD
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A3540631DD
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 8C07D7FF43288E7CB82AB487D66B63FB
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Erase whole flash
Flash erase done
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.47 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:11
Old 05-14-2016, 13:06   #2 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
sir jaydi i did as you told me
erased flash included preloader and read full info
Old 05-14-2016, 13:11   #3 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Operation : Flash [ v1.47 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s5501 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3651 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E2700000
Flash Pre-Erase Done, time used : 00:00:28
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5501.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:42
Old 05-14-2016, 13:12   #4 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
hardware problem ?? could you confirm me please
Old 05-14-2016, 14:53   #5 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
Seems EMMC read only
post HW test logs....
Page generated in 0.24292 seconds with 8 queries
